How can I output results on surface meshes to vtk file?
Recently, I am solving some problems on surfaces with ngsolve. I am wondering if it can output the results to file for surface domains.
The vtk file output by the following code is almost empty. Are the parameters for Vtkoutput wrong?
[code]import netgen.gui
from netgen.csg import *
geo = CSGeometry()
geo.Add(Sphere(Pnt(0,0,0),1))
mesh = Mesh(geo.GenerateMesh(maxh=0.5, perfstepsend=MeshingStep.MESHSURFACE))
V_HS = HDivSurface(mesh)
u = GridFunction(V_HS)
vtk = VTKOutput(ma=mesh,coefs=[u],names=[“sol”],filename=“data/hdiv”)
for i in range(u.space.ndof):
u.vec[:] = 0
u.vec[i] = 1
vtk.Do()[/code]
just use Do(BND) instead of Do() and only the surface mesh will be treated.
Thanks Christoph,
Zongze Yang
