I have defined two dmains with the following.
x = [-1.00,-0.8, 1.0,-0.8]
y = [ 0.80,-1.0,-0.8, 1.0]
pnt = []
pnt.append(Pnt(x[0], y[0], 0))
pnt.append(Pnt(x[1], y[1], 0))
pnt.append(Pnt(x[2], y[2], 0))
pnt.append(Pnt(x[3], y[3], 0))
seg = []
seg.append(Segment(pnt[0], pnt[1]))
seg.append(Segment(pnt[1], pnt[2]))
seg.append(Segment(pnt[2], pnt[3]))
seg.append(Segment(pnt[3], pnt[0]))
wire = Wire (seg)
face1 = Face (wire)
face1.bc("mat1")
circle = WorkPlane().Circle(0,0,3).Face()
face2 = circle - face1
face2.bc("mat2")
face = Glue([face1, face2])
face.edges.Max(X).name="max_X"
face.edges.Min(X).name="min_X"
face.edges.Max(Y).name="max_Y"
face.edges.Min(Y).name="min_Y"
#DrawGeo(face)
from ngsolve import Mesh
geo = OCCGeometry(face, dim=2)
mesh = Mesh(geo.GenerateMesh(maxh=0.5)).Curve(5)
Draw (mesh);
print(mesh.GetMaterials())
print(mesh.GetBoundaries())
I have generaetd the mesh, but matrials are named with “bc” names.
I want to specify the name of the materials.
How do I use .mat() methods? In dim=2, BC labels are used for materials?
BC labels are also strange.
(‘mat1’, ‘mat2’)
(‘default’, ‘min_Y’, ‘default’, ‘max_Y’, ‘default’)
I have modified my Python script as follows.
pnt = []
seg = []
wire = Wire (seg)
face1 = Face (wire)
face1.bc("mat1")
face2.bc("mat2")
face.edges.Nearest((3,0,0)).name="out"
#DrawGeo(face)
#Draw (mesh);
I checkd the BC labels with the following.
fes = H1(mesh, order=1, dirichlet='out')
bdry_values = {'out': 1}
cf = mesh.BoundaryCF(bdry_values, default=0)
gfu.Set(cf, definedon=mesh.Boundaries('out'))
Draw(gfu)
Hi Kengo,
I’ve simplified your script a bit, I like to work with the WorkPlane object. There you can name boundaries as you draw the lines, alternatively you can also use the Nearest like you did or something like Min Max
The occ shapes do not yet know in which dimension they are, this info is just added when you create the OCCGeometry object. So therefore we just name the faces and they will be materials afterwards in the mesh if dim == 2
face1 = MoveTo(x[0], y[0]).LineTo(x[1], y[1], name="test").LineTo(x[2], y[2]).LineTo(x[3], y[3]).Close().Face()
face1.edges.Max(X).name = "out"
face1.faces.name = "mat1"
circle = Circle((0,0),3).Face()
face2.faces.name = "mat2"
#Draw (mesh);
Thank you for the reply. So far, I have understood as follows.
dim = 3 |
dim = 2 |
| material |
solid.name |
face.name |
| boundary |
face.name |
edge.name |
