How to calculate the maximum value of numerical solutions u_h
Hi, everybody!
I want to know how to calculate the maximum value of a numerical solution of dicontinuous Galerkin method?
Thanks,
Yongbin
Hi Yongbin,
In general computing the exact maximum of a (piecewise) polynomial is quite hard, however you can approximate the maximum as follows: you sample your function on a (sufficiently large) set of points, and then you take the maximum of the sampled values.
For example, in two dimensions, I can sample the solution on the vertices and on midpoints of edges. The following function generate a list of points that can be used for evaluation:
def computeQuadPoints(mesh, fes):
# create integration points for fast evaluation
eps = 1e-4
ir = IntegrationRule(points=[(0+eps,0+eps),(0+eps,1-2eps), (1-2eps,0+eps), (0.5,0+eps), (0.5-eps, 0.5- eps), (0+eps,0.5)], weights=[1/6,1/6,1/6,1/6,1/6,1/6])
xpts =
ypts =
zpts =
for e in fes.Elements():
trafo = e.GetTrafo()
for p in ir :
xpts.append(trafo(p).point[0])
ypts.append(trafo(p).point[1])
zpts.append(0)
mips = mesh(xpts, ypts, zpts)
npts = 6
return mips, npts
It is inspired from a code by Gousheng Fu. Then, you can evaluate gfu on mips and take the maximum:
vals = gfu(mips)
maxu = np.max(vals)
I hope this solves your problem.
Enrico
there is a function to get all the mapped integration points from a integration rule on a mesh, so after the intrule line you can also do this one liner:
ir = ...
return mesh.MapToAllElements(ir, VOL)
instead of VOL you can also give a Region to only find maxima on certain regions.
Thank you very much for your advice.
Yongbin Han
Thank you very much!
Yongbin Han
