I just wonder if there is a way of using OCC in the netgen python script. The tutorial only shows using CSG geometry and others. I want to be able to read step file into python script and run the netgen using python file. Thanks a lot for the assistance!
I just added a function to heal the geometry after loading. So you can call .Heal() on a OCCGeometry. It is in our git repo now and a merge request is submitted.
Are you using and self compiled or an installer version of Netgen?
After the merge request is accepted, the change is pushed to github should be in the nightly installer the day after.
Just exploring your viewer.
Really like it.
Even found 1651-how-could-i-import-step-file-as-topods-shape#4462 to convert the occgeometry into a shape so I can view the imported step file prior to creating a mesh.
What I also like is that in the viewer I can mouse-click on a face or edge and the face/edge ID is shown.
Would it be possible to get this information available in my python code?
And would it also be possible for the VERTICES?
And if so, I would also like to have (x,y,z) coordinates related to the face/edge/vertex ID?
