Hi all,
NGSolve is a great tool, but I’m having trouble with some details.
I have set up a solver for my PDE, and calculated inverse of system matrix since I’m solving for many different “right-hand sides”. Now, for bigger meshes, the calculation of the inverse takes some time and I wanted to store the calculated inverse. However, it seems it’s not working like other ngs objects.
Here is the code:
ainv_filename = f'{self.results_dir}/A_inv.npz'
if os.path.exists(ainv_filename)
self.log(f'Loading inverse of stiffness matrix...')
# Load A_inv
self.a_inv.mat = np.load(ainv_filename) # First self.a_inv should be initialized?
self.log(f'Calculating inverse of stiffness matrix...')
self.a_inv = self.a.mat.Inverse(self.fes.FreeDofs())
np.savez_compressed(ainv_filename, self.a_inv.mat)
The calculation is working without issues:
# Compute the solution (using precalculated inverse of stifness matrix A)
self.gfu.vec.data = self.a_inv * self.f.vec
To sum it up, how can I save BaseMatrix values to a file (NumPy or any other format)?
Hi Matthiash,
I’ve updated ngsolve to the latest and now I can pickle SparseCholesky objects.
However, this comes with an excessive memory consumption and script/program crashes (Calculating inverse is already at about 27 GB, and pickling consumes the remaining 5GB on this machine).
Is there a way or advice on how to do it “manually”?
