How to use BDM element in a quadrilateral mesh?
When running the following code:
import ngsolve.meshes as ngm
mesh = ngm.MakeStructured2DMesh(nx=1,ny=1)
V = HDiv(mesh, order=2, RT=False)
gfu = GridFunction(V)
vtk = VTKOutput(ma=mesh, coefs=[gfu], names=["bdm-basis"], filename="bdm2basis", subdivision=3)
for i in range(gfu.vec.size):
    gfu.vec[:] = 0
    gfu.vec[i] = 1
    vtk.Do()
I find there are 24 vtk documents shown, which should be RT2 basis in a rectangle. But I have used RT=False, my question is: how to use BDM element in a quadrilateral mesh?
Di Yang
Hi Di Yang,
to check the number of degrees of freedom on a single quad for different polynomial orders you can use the following code
[code]from ngsolve import *
from ngsolve.meshes import MakeStructured2DMesh
mesh = MakeStructured2DMesh(quads=True,nx=1,ny=1)
print(“RT”)
for p in range(6):
fes = HDiv(mesh, order=p, RT=True)
print(p,“:”,fes.ndof)
print(“BDM”)
for p in range(6):
fes = HDiv(mesh, order=p+1)
print(p,“:”,fes.ndof)[/code]
which gives the output
RT: 0 : 4, 1 : 12, 2 : 24, 3 : 40, 4 : 60, 5 : 84
BDM: 0 : 12, 1 : 24, 2 : 40, 3 : 60, 4 : 84, 5 : 112
As you can see they coincide (RT is “shifted”). The reason for this is that RT elements are available for triangles and tetrahedra, but not for quadrilaterals, hexahedra, or prisms. So there are only BDM elements for quads.
Thank u first for your specific replies. However, the dofs of BDMk on any rectangle K are devised as follows.
[tex]
(\mathbf{w}\cdot\mathbf{n}, p_k){e_i},\quad \forall,p_k\in P_k(e_i),\ i=1,2,3,4;
[/tex]
[tex]
(\mathbf{w}, \mathbf{p}
{k-2})K,\quad \forall,\mathbf{p}{k-2}\in (P_{k-2}(K))^2.
[/tex]
So, it should be
[tex]
\mathrm{dim}(BDMk)=k^2+3k+4,
[/tex]
i.e., BDMk
k=1: 8;
k=2: 14;
k=3: 22;
k=4: 32;
But if running
the number of dofs of V is 24. I think it is not a BDM2.
Di Yang
Could be that it is exactly the other way round, sorry.
The Quad-HDiv basis in NGSolve is implemented as described in this thesis.
The basis span Q_{k+1,k} x Q_{k,k+1} if I remember correctly and thus has dimension 2*(k+2)*(k+1)=2k**2+6k+4.
Ok, that means RTk elements indeed. Thank u very much.
