Hi everybody,
Just a simple question, is it possible to import IGES (or STL, STEP, whatever) data into Netgen using the Python interface? I couldn’t find anything in the documentation nor in the forum.
Thanks in advance for any response
Ingo
Hi ingo,
Maybe this will help:
import netgen.stl as stl
geo2 = stl.LoadSTLGeometry("input.stl")
m2 = geo2.GenerateMesh (maxh=0.05)
Dow
If you’ve compiled netgen with occ support (or used one of the installers) then you can load step files as well:
from netgen import NgOCC
geo = NgOCC.LoadOCCGeometry("geo.step")
I do the following and everything works well:
geo1 = NgOCC.OCCGeometry("geo1.stp")
geo2 = NgOCC.OCCGeometry("geo2.stp")
But when I try to do this
final = geo1 - geo2
Netgen gives an error “unsupported operand type for -”.
Is it possible to work with STEP geometry using the Python interface?
Thanks in advance for any response.
Hi, manipulating step geometries is not possible in NGSolve. You need to use a geometric modeller for that (for example open source tool Opencascade). Then you can load the final geometry and mesh it using Netgen.
