Hi everyone,
I’ve been using the BiCGStab solver from PETSc in NGSolve for some time now. While it works well, I’ve encountered significant computational overhead when converting large NGSolve matrices to PETSc matrices. I attempted to implement the BiCGStab solver directly within NGSolve to address this issue based on C code. However, my implementation has not been converging as expected. Below, I include my implementation and a simple test case, and I’d appreciate any feedback or suggestions for improvement.
from ngsolve import (
BaseVector,
Norm,
ngsglobals,
H1,
y,
x,
Mesh,
LinearForm,
BilinearForm,
grad,
dx,
GridFunction,
sqrt,
Integrate,
Draw
from ngsolve.krylovspace import LinearSolver
class BiCGStabSolver(LinearSolver):
def __init__(
self,
*args,
conjugate: bool = False,
abstol: float = None,
maxsteps: int = None,
printing: bool = False,
**kwargs
if printing:
print("WARNING: printing is deprecated, use printrates instead!")
kwargs["printrates"] = printing
if abstol is not None:
print("WARNING: abstol is deprecated, use atol instead!")
kwargs["abstol"] = abstol
if maxsteps is not None:
print("WARNING: maxsteps is deprecated, use maxiter instead!")
kwargs["maxiter"] = maxsteps
super().__init__(*args, **kwargs)
self.conjugate = conjugate # for backward compatibility
@property
def errors(self):
return self.residuals
def _SolveImpl(self, rhs: BaseVector, sol: BaseVector):
r, r_tilde, p, p_tilde, s, s_tilde, t, v = [sol.CreateVector() for i in range(8)]
conjugate = self.conjugate
r.data = rhs - self.mat * sol
r_tilde.data = r
rho_new = r_tilde.InnerProduct(r, conjugate=conjugate)
p.data = r
p_tilde.data = self.pre * p
v.data = self.mat * p_tilde
alpha = rho_new / r_tilde.InnerProduct(v, conjugate=conjugate)
s.data = r
s.data -= alpha * v
s_tilde.data = self.pre * s
t.data = self.mat * s_tilde
omega = t.InnerProduct(s, conjugate=conjugate) / t.InnerProduct(t, conjugate=conjugate)
sol.data += alpha * p_tilde + omega * s_tilde
r.data = s
r.data -= omega * t
err_i = Norm(r)
if self.CheckResidual(err_i):
return
while True:
rho_old = rho_new
beta = (rho_new / rho_old) * (alpha / omega)
p.data = r + beta * (p - omega * v)
s.data = r
s.data -= alpha * v
err_i = Norm(s)
if err_i <= err_i*1e-8:
break
sol.data += omega * s_tilde
r.data = s
r.data -= omega * t
err_i = Norm(r)
return
def BiCGStab(
mat,
rhs,
pre=None,
sol=None,
tol=1e-12,
maxsteps=100,
printrates=True,
initialize=True,
conjugate=False,
callback=None,
**kwargs
"""preconditioned biconjugate gradient stabalized method Returns
(vector)
Solution vector of the BiCGStab method."""
solver = BiCGStabSolver(
mat=mat,
pre=pre,
conjugate=conjugate,
tol=tol,
maxiter=maxsteps,
callback=callback,
printrates=printrates,
**kwargs
solver.Solve(rhs=rhs, sol=sol, initialize=initialize)
return solver.sol
ngsglobals.msg_level = 1 # generate a triangular mesh of mesh-size 0.2
mesh = Mesh(unit_square.GenerateMesh(maxh=0.2)) # H1-conforming finite element space
fes = H1(mesh, order=3, dirichlet=[1, 2, 3, 4]) # define trial- and test-functions
u = fes.TrialFunction()
v = fes.TestFunction() # the right hand side
f += 32 * (y * (1 - y) + x * (1 - x)) * v * dx
# the bilinear-form
a += grad(u) * grad(v) * dx
# the solution field
gfu_1 = GridFunction(fes)
gfu_1.vec.data = a.mat.Inverse(fes.FreeDofs(), inverse="sparsecholesky") * f.vec
preJpoint = a.mat.CreateSmoother(fes.FreeDofs())
inv = BiCGStabSolver(
a.mat, pre=preJpoint, maxiter=50, tol=1e-8, printrates=True, conjugate=False
gfu_2 = GridFunction(fes)
gfu_2.vec.data = inv.Solve(f.vec, initialize=False)
print("L2-error:", sqrt(Integrate((gfu_1 - gfu_2) * (gfu_1 - gfu_2), mesh)))
Draw(gfu_2)
I have also tried to implement the pseudo-code in the book. Both gave the same results.
def _SolveImpl(self, rhs : BaseVector, sol : BaseVector):
r_tilde.data = r
p.data = r
for i in range(1,self.maxiter+1):
print(i)
s.data = r
s.data -= alpha * v
err_i = Norm(s)
break
r.data = s
r.data -= omega * t
err_i = Norm(r)
return
rho_old = rho_new
