after some time away from ngsolve I wanted to do some computation for which I tried to install netgen/ngsolve on my private PC. I run Linux Mint 20.1 and therefore followed your build on linux instructions. However, after calling make I get the error “No module named ‘netgen’”; more specific:
File "/usr/lib/python3.8/runpy.py", line 194, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/lib/python3.8/runpy.py", line 87, in _run_code
exec(code, run_globals)
File "/home/phil/.local/lib/python3.8/site-packages/pybind11_stubgen/__main__.py", line 4, in <module>
main()
File "/home/phil/.local/lib/python3.8/site-packages/pybind11_stubgen/__init__.py", line 915, in main
_module = ModuleStubsGenerator(_module_name)
File "/home/phil/.local/lib/python3.8/site-packages/pybind11_stubgen/__init__.py", line 666, in __init__
self.module = importlib.import_module(module_or_module_name)
File "/usr/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 973, in _find_and_load_unlocked
ModuleNotFoundError: No module named 'netgen'
CMake Error at python/cmake_install.cmake:59 (file):
file INSTALL cannot find
"/home/phil/Programme/NGSolve/ngsolve-build/netgen/netgen/python/../stubs/netgen-stubs":
No such file or directory.
As I am still a bit of a newcomer to linux I don’t really know how to resolve this problem (or even where to start).
Already thanks for any help.
it looks to me as if the error is occurring when the stubfiles for autocompletion in an editor are attempted to be generated. Maybe try building without them, i.e., set the make option -DBUILD_STUB_FILES=OFF Otherwise I would try setting the all the necessary environment variables in your .bashrc before building and compiling ngsolve.
thanks for your advice - make runs through just fine, however I get the same message when calling ‘make install’:
[code]-- Installing: /home/phil/Programme/NGSolve/ngsolve-build/ngsolve-install/lib/python3/dist-packages/ngsolve/labextension/package.json
File “/usr/bin/jupyter-nbextension”, line 11, in
load_entry_point(‘notebook==6.0.3’, ‘console_scripts’, ‘jupyter-nbextension’)()
File “/usr/lib/python3/dist-packages/jupyter_core/application.py”, line 270, in launch_instance
return super(JupyterApp, cls).launch_instance(argv=argv, **kwargs)
File “/usr/lib/python3/dist-packages/traitlets/config/application.py”, line 664, in launch_instance
app.start()
File “/usr/lib/python3/dist-packages/notebook/nbextensions.py”, line 983, in start
super(NBExtensionApp, self).start()
File “/usr/lib/python3/dist-packages/jupyter_core/application.py”, line 259, in start
self.subapp.start()
File “/usr/lib/python3/dist-packages/notebook/nbextensions.py”, line 711, in start
self.install_extensions()
File “/usr/lib/python3/dist-packages/notebook/nbextensions.py”, line 682, in install_extensions
full_dests = install(self.extra_args[0],
File “/usr/lib/python3/dist-packages/notebook/nbextensions.py”, line 206, in install_nbextension_python
m, nbexts = _get_nbextension_metadata(module)
File “/usr/lib/python3/dist-packages/notebook/nbextensions.py”, line 1117, in _get_nbextension_metadata
m = import_item(module)
File “/usr/lib/python3/dist-packages/traitlets/utils/importstring.py”, line 42, in import_item
return import(parts[0])
ModuleNotFoundError: No module named ‘ngsolve’
Error in sys.excepthook:
File “/usr/lib/python3/dist-packages/apport_python_hook.py”, line 153, in apport_excepthook
with os.fdopen(os.open(pr_filename,
FileNotFoundError: [Errno 2] No such file or directory: ‘/var/crash/_usr_bin_jupyter-nbextension.1000.crash’
I already tried your solution but to no avail. However, it seems that my problem was correlated to jupyter - can’t exactly point it out, but after a fresh installation of jupyter it works now.
