Installation dcm dualcellspaces
Hi, I tried to install dcm from 1. Installation — The Dual Cell Method in NGSolve
but the installation ends with this error:
File “/tmp/tmpcc47w85c/wheel/platlib/dualcellspaces/init.py”, line 2, in
from .dualcellspaces import *
ImportError: generic_type: type “H1DualCells” referenced unknown base type “ngcomp::FESpace”
CMake Error at /tmp/tmpcc47w85c/build/cmake_install.cmake:120 (file):
file INSTALL cannot find “/tmp/tmpcc47w85c/build/stubs/dualcellspaces”: No
such file or directory.
I tried both with the CMake and the pip installation, but both resulted in the same error. Is seems like the dualspaces file does not exist. Is it an error in the package?
Hi Richard,
it seems like an issue with pybind11_stubgen. Is it installed?
python -m pip install pybind11_stubgen
Yes it is installed:
Requirement already satisfied: pybind11_stubgen in ./.venv/lib/python3.12/site-packages (2.5.1)
It still seems like an issue with stubgen. When using CMake to compile you can omit using it by commenting out the last line in the CMakeLists.txt, i.e.,
# ngsolve_generate_stub_files(${addon_name})
Thanks, I did as you suggested and it compiled. When I tried python -m dualcellspaces.demos.test_spaces I got this problem:
  File "<frozen runpy>", line 189, in _run_module_as_main
  File "<frozen runpy>", line 112, in _get_module_details
  File "./.venv/lib/python3.12/site-packages/dualcellspaces/__init__.py", line 2, in <module>
ImportError: generic_type: type "H1DualCells" referenced unknown base type "ngcomp::FESpace"
Interesting. Which version of NGSolve are you running?
It is NGSolve-6.2.2406
The error suggests that NGSolve and dualcellspaces where compiled with incompatible compilers or compiler flags (meaning, they are considered incompatible by pybind11).
This means that pybind11 wants to export the type H1DualCells, but the base class ngcomp::FESpace was not exported yet.
Which compiler do you use to build dualcellspaces, do you have CXX environment variables set?
The ngsolve pip package (I assume u used that one?) is built with gcc.
I had not set CXX, seems like it used /usr/bin/c++ by default. I tried to use gcc now. However, I got the same error:
cmake .. -DCMAKE_C_COMPILER=/usr/bin/gcc -DCMAKE_CXX_COMPILER=/usr/bin/gcc
-- The C compiler identification is GNU 9.4.0
-- The CXX compiler identification is GNU 9.4.0
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/gcc
-- Check for working CXX compiler: /usr/bin/gcc -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found Python3: ~/.venv/bin/python3 (found version "3.12.8") found components: Interpreter Development
-- Found Netgen: ~/.venv/lib/cmake/netgen
-- Install dir: ~/.venv
-- Configuring done
-- Generating done
-- Build files have been written to: ~/dcm/build
: ~/dcm/build$ make CXX=/usr/bin/gcc -j4 install
Scanning dependencies of target dualcellspaces
[ 10%] Building CXX object CMakeFiles/dualcellspaces.dir/src/h1primalcells.cpp.o
[ 20%] Building CXX object CMakeFiles/dualcellspaces.dir/src/h1dualcells3d.cpp.o
[ 30%] Building CXX object CMakeFiles/dualcellspaces.dir/src/dualcellspaces.cpp.o
[ 40%] Building CXX object CMakeFiles/dualcellspaces.dir/src/h1dualcells.cpp.o
[ 50%] Building CXX object CMakeFiles/dualcellspaces.dir/src/hcurldualcells.cpp.o
[ 60%] Building CXX object CMakeFiles/dualcellspaces.dir/src/hcurlprimalcells.cpp.o
[ 70%] Building CXX object CMakeFiles/dualcellspaces.dir/src/hdivprimalcells.cpp.o
[ 80%] Building CXX object CMakeFiles/dualcellspaces.dir/src/intrules.cpp.o
[ 90%] Building CXX object CMakeFiles/dualcellspaces.dir/src/supersparse.cpp.o
[100%] Linking CXX shared library dualcellspaces.so
[100%] Built target dualcellspaces
Install the project...
-- Install configuration: "RelWithDebInfo"
-- Installing: ~/.venv/lib/python3.12/site-packages/dualcellspaces/dualcellspaces.so
-- Set runtime path of "~/.venv/lib/python3.12/site-packages/dualcellspaces/dualcellspaces.so" to ""
-- Up-to-date: ~/.venv/lib/python3.12/site-packages/dualcellspaces/__init__.py
-- Up-to-date:~/.venv/lib/python3.12/site-packages/dualcellspaces/demos/dc_intrules.py
-- Up-to-date: ~/.venv/lib/python3.12/site-packages/dualcellspaces/demos/test_spaces.py
~/dcm/build$ python -m dualcellspaces.demos.dc_intrules
not sure if I’m doing it correctly.
using pip instead I got this error:
pip install git+https://github.com/NGSolve/dcm.git
Building wheels for collected packages: dualcellspaces
Building wheel for dualcellspaces (pyproject.toml) … error
error: subprocess-exited-with-error
× Building wheel for dualcellspaces (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [69 lines of output]
2024-12-11 16:11:05,591 - scikit_build_core - WARNING - cmake should not be in build-system.requires - scikit-build-core will inject it as needed
*** scikit-build-core 0.10.7 using CMake 3.31.1 (wheel)
*** Configuring CMake…
loading initial cache file /tmp/tmpyn75i9dd/build/CMakeInit.txt
– The C compiler identification is GNU 9.4.0
– The CXX compiler identification is GNU 9.4.0
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Check for working C compiler: /usr/bin/gcc - skipped
– Detecting C compile features
– Detecting C compile features - done
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Check for working CXX compiler: /usr/bin/g++ - skipped
– Detecting CXX compile features
– Detecting CXX compile features - done
– Found Python3: /mnt/samsung4tb/pyNgsDCM/bin/python3 (found version “3.12.8”) found components: Interpreter Development.Module
– Found Netgen: /tmp/pip-build-env-t6ovyl2v/overlay/lib/cmake/netgen
– Install dir: /tmp/tmpyn75i9dd/wheel/platlib
– Configuring done (1.6s)
– Generating done (0.0s)
– Build files have been written to: /tmp/tmpyn75i9dd/build
*** Building project with Ninja…
[1/10] Building CXX object CMakeFiles/dualcellspaces.dir/src/supersparse.cpp.o
[2/10] Building CXX object CMakeFiles/dualcellspaces.dir/src/intrules.cpp.o
[3/10] Building CXX object CMakeFiles/dualcellspaces.dir/src/h1dualcells3d.cpp.o
[4/10] Building CXX object CMakeFiles/dualcellspaces.dir/src/h1dualcells.cpp.o
[5/10] Building CXX object CMakeFiles/dualcellspaces.dir/src/h1primalcells.cpp.o
[6/10] Building CXX object CMakeFiles/dualcellspaces.dir/src/hcurlprimalcells.cpp.o
[7/10] Building CXX object CMakeFiles/dualcellspaces.dir/src/hdivprimalcells.cpp.o
[8/10] Building CXX object CMakeFiles/dualcellspaces.dir/src/dualcellspaces.cpp.o
[9/10] Building CXX object CMakeFiles/dualcellspaces.dir/src/hcurldualcells.cpp.o
[10/10] Linking CXX shared library dualcellspaces.so
*** Installing project into wheel…
– Install configuration: “Release”
– Installing: /tmp/tmpyn75i9dd/wheel/platlib/dualcellspaces/dualcellspaces.so
– Set non-toolchain portion of runtime path of “/tmp/tmpyn75i9dd/wheel/platlib/dualcellspaces/dualcellspaces.so” to “”
– Installing: /tmp/tmpyn75i9dd/wheel/platlib/dualcellspaces/init.py
– Installing: /tmp/tmpyn75i9dd/wheel/platlib/dualcellspaces/demos/dc_intrules.py
– Installing: /tmp/tmpyn75i9dd/wheel/platlib/dualcellspaces/demos/test_spaces.py
File “”, line 198, in _run_module_as_main
File “”, line 88, in _run_code
File “/tmp/pip-build-env-t6ovyl2v/overlay/lib/python3.12/site-packages/pybind11_stubgen/main.py”, line 4, in
main()
File “/tmp/pip-build-env-t6ovyl2v/overlay/lib/python3.12/site-packages/pybind11_stubgen/init.py”, line 319, in main
run(
File “/tmp/pip-build-env-t6ovyl2v/overlay/lib/python3.12/site-packages/pybind11_stubgen/init.py”, line 358, in run
QualifiedName.from_str(module_name), importlib.import_module(module_name)
File “~/.pyenv/versions/3.12.8/lib/python3.12/importlib/init.py”, line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1387, in _gcd_import
File “”, line 1360, in _find_and_load
File “”, line 1331, in _find_and_load_unlocked
File “”, line 935, in _load_unlocked
File “”, line 999, in exec_module
File “”, line 488, in _call_with_frames_removed
File “/tmp/tmpyn75i9dd/wheel/platlib/dualcellspaces/init.py”, line 2, in
CMake Error at /tmp/tmpyn75i9dd/build/cmake_install.cmake:129 (file):
file INSTALL cannot find “/tmp/tmpyn75i9dd/build/stubs/dualcellspaces”: No
  *** CMake install failed
  [end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for dualcellspaces
Failed to build dualcellspaces
ERROR: ERROR: Failed to build installable wheels for some pyproject.toml based projects (dualcellspaces)
Which OS are you running (and which version)?
g++ or gcc doesn’t matter, both are fine. I was meaning other compiler suites than the gcc suite (clang for instance).
Maybe it’s about the compiler version, I will try to reproduce this once I know your OS.
It is Ubuntu 20.04.6 LTS (Focal Fossa)
One more question:
How did you install NGSolve? I think it’s using different versions of NGSolve when building the plugin and at run time (due to build-isolation).
Try to install with
pip install --no-build-isolation other_args...
I did this:
python -m pip install numpy scipy matplotlib jupyter ipyparallel scikit-build
python -m pip install --upgrade ngsolve webgui_jupyter_widgets
I will try with --no-build-isolation
Thanks!
I got the same error using --no-build-isolation. This is what I tried:
python -m pip install --no-build-isolation ngsolve webgui_jupyter_widgets
python -m pip install --no-build-isolation git+https://github.com/NGSolve/dcm.git
Output from python -m pip install --no-build-isolation git+https://github.com/NGSolve/dcm.git:
  Building wheel for dualcellspaces (pyproject.toml) ... error
  │ exit code: 1
  ╰─> [73 lines of output]
      2024-12-12 09:53:34,532 - scikit_build_core - WARNING - cmake should not be in build-system.requires - scikit-build-core will inject it as needed
      *** scikit-build-core 0.10.7 using CMake 3.16.3 (wheel)
      *** Configuring CMake...
      loading initial cache file /tmp/tmpm1k8aiiw/build/CMakeInit.txt
      -- Check for working CXX compiler: /usr/bin/g++
      -- Check for working CXX compiler: /usr/bin/g++ -- works
      -- Found Python3: /mnt/samsung4tb/pyNgsDCM2/bin/python (found version "3.12.8") found components: Interpreter Development Development.Module Development.Embed
      -- Found Netgen: /mnt/samsung4tb/pyNgsDCM2/lib/cmake/netgen
      -- Install dir: /tmp/tmpm1k8aiiw/wheel/platlib
      -- Configuring done
      -- Generating done
      -- Build files have been written to: /tmp/tmpm1k8aiiw/build
      *** Building project with Unix Makefiles...
      [ 10%] Building CXX object CMakeFiles/dualcellspaces.dir/src/dualcellspaces.cpp.o
      [ 20%] Building CXX object CMakeFiles/dualcellspaces.dir/src/h1dualcells.cpp.o
      [ 30%] Building CXX object CMakeFiles/dualcellspaces.dir/src/h1dualcells3d.cpp.o
      [ 40%] Building CXX object CMakeFiles/dualcellspaces.dir/src/h1primalcells.cpp.o
      *** Installing project into wheel...
      -- Install configuration: "Release"
      -- Installing: /tmp/tmpm1k8aiiw/wheel/platlib/dualcellspaces/dualcellspaces.so
      -- Set runtime path of "/tmp/tmpm1k8aiiw/wheel/platlib/dualcellspaces/dualcellspaces.so" to ""
      -- Installing: /tmp/tmpm1k8aiiw/wheel/platlib/dualcellspaces/__init__.py
      -- Installing: /tmp/tmpm1k8aiiw/wheel/platlib/dualcellspaces/demos/dc_intrules.py
      -- Installing: /tmp/tmpm1k8aiiw/wheel/platlib/dualcellspaces/demos/test_spaces.py
        File "<frozen runpy>", line 198, in _run_module_as_main
        File "<frozen runpy>", line 88, in _run_code
        File "/mnt/samsung4tb/pyNgsDCM2/lib/python3.12/site-packages/pybind11_stubgen/__main__.py", line 4, in <module>
          main()
        File "/mnt/samsung4tb/pyNgsDCM2/lib/python3.12/site-packages/pybind11_stubgen/__init__.py", line 319, in main
          run(
        File "/mnt/samsung4tb/pyNgsDCM2/lib/python3.12/site-packages/pybind11_stubgen/__init__.py", line 358, in run
        File "~/.pyenv/versions/3.12.8/lib/python3.12/importlib/__init__.py", line 90, in import_module
        File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
        File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
        File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
        File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
        File "<frozen importlib._bootstrap_external>", line 999, in exec_module
        File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
        File "/tmp/tmpm1k8aiiw/wheel/platlib/dualcellspaces/__init__.py", line 2, in <module>
      CMake Error at /tmp/tmpm1k8aiiw/build/cmake_install.cmake:120 (file):
        file INSTALL cannot find "/tmp/tmpm1k8aiiw/build/stubs/dualcellspaces": No
      [end of output]
Hi, just wanted to let you know that I installed and ran dcm on another OS (Debian 12.2) without any problem.
