Installation issue via pip
Hello, I was trying to install Netgen via pip.
But, I had an error message like below
What should I do to fix this error?
Thanks!
You seem to have installed TBB with another package manager, likely system one. Either fix this, for example like explained here or install ngsolve in a fresh venv.
I made a virtual environment in Anaconda.
But, still I have the issue like below.
I used
“conda install ngsolve” or “conda install -c ngsolve ngsolve” command for the installation.
Either did not work.
Also, I tried to install NGSolve in different python version (3.10). But, still it didn’t work.
Try installing ngsolve with pip in the virtual environment. I think the conda installers are not up to date.
