I am following the instructions to install ngsolve on Linux and am currently at the step: “Building”.
Calling make throws the following errors which I am not sure to pinpoint to a certain source:
ana_orderings_wrappers_m.F:315:39:
314 | CALL MUMPS_COPY_INT_32TO64 (FRERE(1), NCMP, FRERE8)
| 2
315 | CALL MUMPS_COPY_INT_32TO64 (OPTIONS_METIS, LOPTIONS_METIS,
| 1
Fehler: Unverträgliche Ränge zwischen Argument bei (1) und Argument bei (2) (skalar und Rang-1)
ana_orderings_wrappers_m.F:318:29:
284 | CALL METIS_NODEND( NCMP, IPE8, IW, FRERE(1),
| 2
318 | CALL METIS_NODEND( int(NCMP,8), IPE8, IW, FRERE8,
| 1
Fehler: Unverträgliche Typen zwischen Argument bei (1) und Argument bei (2) (INTEGER(8)/INTEGER(4)).
ana_orderings_wrappers_m.F:321:29:
| 2
321 | CALL METIS_NODEND( int(NCMP,8), IPE8, IW8, FRERE8,
| 1
ana_orderings_wrappers_m.F:324:50:
324 | CALL MUMPS_COPY_INT_64TO32(IKEEP18, NCMP, IKEEP1(1))
| 1
644 | & size(PARTS), PARTS)
| 2
Fehler: Element des Feldes mit vermuteter Form oder von Zeigern bei (1) kann nicht zum Argument bei (2) passen
ana_orderings_wrappers_m.F:325:50:
325 | CALL MUMPS_COPY_INT_64TO32(IKEEP28, NCMP, IKEEP2(1))
| 1
| 2
ana_orderings_wrappers_m.F:114:31:
114 | CALL METIS_NODEND( NCMP, IPE, IW, FRERE(1),
| 1
| 2
Fehler: Unverträgliche Typen zwischen Argument bei (1) und Argument bei (2) (INTEGER(4)/INTEGER(8)).
ana_orderings_wrappers_m.F:116:33:
116 | CALL MUMPS_COPY_INT_32TO64(IPE, NCMP+1, IPE8)
| 1
| 2
make[6]: *** [Makefile:381: ana_orderings_wrappers_m.o] Fehler 1
make[5]: *** [Makefile:20: c] Fehler 2
make[4]: *** [Makefile:40: mumps_lib] Fehler 2
make[3]: *** [Makefile:18: c] Fehler 2
make[2]: *** [CMakeFiles/project_mumps.dir/build.make:86: dependencies/src/project_mumps-stamp/project_mumps-build] Fehler 2
make[1]: *** [CMakeFiles/Makefile2:254: CMakeFiles/project_mumps.dir/all] Fehler 2
make: *** [Makefile:156: all] Fehler 2
Can someone help me with this?
Thanks in advance.
