I am using Python 3.10.5 on Windows 10 pro.
I tried to use pip to install the following script
python -m pip install --upgrade jupyter
python -m pip install --upgrade jupyter_contrib_nbextensions
python -m pip install --upgrade webgui_jupyter_widgets
jupyter nbextension install --user --py webgui_jupyter_widgets
jupyter nbextension enable --user --py webgui_jupyter_widgets
accoding to the following url https://ngsolve.org/downloads
However, it says that notebook is too new to install and even when I installed the older versions of the notebook, still it did not work out.
If you go here:
Keep it up to date
To update Netgen/NGSolve go to the source directory (${BASEDIR}/ngsolve-src) and fetch the latest sources.
git pull
git submodule update --recursive --init
Note: the second line is needed to update all dependencies provided as git submodules (such as Netgen).
Then, go to the build directory (${BASEDIR}/ngsolve-build) and build/install again:
make
(or run make -j4)
make install
to the very end, I say how I installed it. I do this:
First, install it by:
sudo apt update
sudo apt install jupyter
pip install --upgrade ipykernel
pip install webgui_jupyter_widgets
jupyter nbextension install --user --py widgetsnbextension
jupyter nbextension enable --user --py widgetsnbextension
I think the main thing is doing the sudo apt install jupyter, and the ipykernel.
I removed all the package and installed with
python -m pip install --upgrade ngsolve
I could run Jupyter with no problems.
