Dear NGSolve users and developers,
I read the section “Interpolate a CoefficientFunction” of
https://ngsolve.org/docu/nightly/i-tutorials/unit-1.2-coefficient/coefficientfunction.html
and I would like to interpolate a vector expression to a vector function following the same
snippet. How should I do that?
Below you can find a code where I try to
a) interpolate from scalar expression to scalar space: this is working correctly
b) interpolate from scalar expression to each component of vector space: this is working correctly
c) my case, interpolate from vector expression to vector function, and two ways I tried, and the corresponding errors
Thanks,
best regards,
Makis
[code]from ngsolve import *
ngsglobals.msg_level = 0
mesh = Mesh (unit_square.GenerateMesh(maxh=0.2))
myfunc = x*(1-x)
a) Interpolate from scalar expression to scalar space: working
V1 = H1(mesh, order=1)
u1 = GridFunction(V1)
u1.Set(myfunc)
print(u1.vec.Norm())
b) Interpolate from scalar expression to each component of vector space: working
V2 = FESpace([V1, V1])
u2 = GridFunction(V2)
u20 = 2u1
u21 = 3u1
u2.components[0].Set(u20)
u2.components[1].Set(u21)
print(u2.vec.Norm(), u1.vec.Norm()*sqrt(13))
c) Interpolate from vector expression to vector function
u3 = GridFunction(V2)
u2_double = 2*u2
c1)
u3.Set(u2_double) # Segmentation fault
c2)
u3.components[0].Set(u2_double[0]) # RuntimeError: don’t know my dimension, space is N6ngcomp15CompoundFESpaceE
u3.components[1].Set(u2_double[1])
print(u3.vec.Norm(), u1.vec.Norm()*2)[/code]
