Issue with Projector
Hi everyone,
the projector object is behaving unexpectedly: It’s zeroing out everything. I’ve attached a MWE to illustrate this. Is this a bug or has the usage of the projector object changed?
Best wishes,
Henry
Attachment: mwe.py
Hi Henry,
using
gfu.vec.data = projector*gfu.vec
leads to undefined behavior as the gfu object appears on the left and right side.
Replacing the line with
tmp = gfu.vec.CreateVector()
tmp.data = projector*gfu.vec
gfu.vec.data = tmp
should solve the problem.
Hi Michael,
thank you for the quick reply! Thats solved the issue :).
Best wishes,
Henry
you can apply the projector inplace via
projector.Project(gfu.vec)
Hi Joachim,
thank you for the tip!
Best wishes,
Henry
