Linear combination of point sources
Hi! I only recently learned that there is a canonical way to define point sources for the right hand side of PDEs, being
v = fes.TrialFunction()
f += v(0.7, 0.5)
for a point source centered in (0.7,0.5). Let us assume I now want my right hand side to be an arbitrary linear combination of point sources. However, a code on the form
f += 3 * v(0.7, 0.5) + v(-0.3,0.6)
does not work, as apparently PointEval functions can be neither multiplied by floats nor added together (meaning just adding them one by one in a loop is also out, as my weights are not all 1).
I can make this work by defining a secondary LinearForm, adding a point source to it, then adding a multiple of its vector to f, i.e.
f0 = LinearForm(fes)
f0 += v(0.7, 0.5)
f0.Assemble()
f.vec.data += 3 * f0.vec.data
f0 += v(-0.3, 0.6)
f0.Assemble()
f.vec.data += f0.vec.data
does work, but seems very clunky and slow due to the need to constantly assemble and redefine the utility-LinearForm f0, even though it’s at least loopable. Is there a better way?
For reference, I am presumably going to be adding a very large number of point sources together, possibly as a complex linear combination.
Cheers,
Christian
you can scale them before the point-evaluation:
f += (3*v)(0.5, 0.7)
Then you can add many of them in a loop.
Oh, that really is an easy fix, thanks so much! Out of curiosity, why is the syntax 3*v(x,y) not possible and not equivalent to (3*v)(x,y)?
A second question, too: How close is this form of “pointwise evaluation” to a true pointwise evaluation/delta Dirac? Does it use some trick to provide an “actual” pointwise evaluation, or is it approximated by a high-order local integral?
simple answer: no particular rison, just not implemented
it is exact point evaluation. We search for the triangle containing the point, compute local coordinates of the point, and evaluate the finite element basis functions there
