mac install problems
I recently switched computers to a mac running OS 10.15.4. I have python 3.8 installed and ran the dmg installer. I can open the netgen gui and load meshes, but when I try to solve a PDE my computer can’t find the ngsolve module. For example, here’s the output when I try to run the poisson.py example
NETGEN-6.2-dev
togl-version : 2
OCC module loaded
loading ngsolve library
NGSolve-6.2.2004
Using Lapack
Running parallel using 4 thread(s)
File “”, line 1, in
ModuleNotFoundError: No module named ‘ngsolve’
File “”, line 1, in
(should) load python file ‘poisson.py’
File “”, line 1, in
File “”, line 4, in
ModuleNotFoundError: No module named ‘netgen’
Finished executing poisson.py
Any ideas as to what’s going on?
I guess you still need to set the environment variables correctly. This is described in the “Getting started with Netgen” section of the documentation:
https://ngsolve.org/docu/latest/install/gettingstarted.html#mac-os-x
EDIT: Opening Netgen from the Launchpad (and not from the command line) should work without setting environment variables as described above. This is working on my Mac (10.15.5 Beta, 6.2.2004 dmg, Python 3.8.2)
Did you have NGSolve installed before (maybe a self-compiled version)? Check if there are environment variables (like DYLD_LIBRARY_PATH etc.) pointing to another NGSolve installation
Have you set your PYTHONPATH correctly? See here:
You’re right. I thought I had my environment variables set correctly, but I hadn’t noticed the getting started page is written for python 3.7. I changed the 3.7 to 3.8 and now it works. That’s what I get for copy-pasting without reading, I suppose.
Thanks for the help!
Good point, I will update the documentation.
