Hi all,
We have rather large geometries comprising multiple objects (up to a few thousand), which we generate using OCC. We found that a lot of memory is allocated in the geometry creation process.
When running NGSolve with MPI, where the geometry has to be known on all ranks to permit curved elements, the huge memory consumption is a bottleneck.
As a workaround, we found that exporting the geometry in BREP format works well:
The exported geometries can be used to curve a previously generated mesh and they consume very little memory.
The STEP export did not work very well because some geometries are not correctly exported (missing faces and volumes of intersecting objects).
Has anyone else faced similar issues and knows a better solution?
Otherwise, we’d be glad if the BREP export could be integrated into Netgen so that we can share our scripts using an official Netgen/NGsolve release.
