Hi, I want to implement adaptive mesh refinement for time-dependant problem. I need to create new mesh, fes and GridFunction in the time-loop.
But, it will cause memory leak. Following is a small test code:
# import gc
# gc.enable()
def Setup():
mesh = Mesh(unit_square.GenerateMesh(maxh=1))
for i in range(8):
fes = H1(mesh, order=1, autoupdate=True)
phi_old = GridFunction(fes, autoupdate=True)
phi_old.Set(k) # <-- turn on this line will cause memory leak
del phi_old
# gc.collect()
print("mesh number = {} ".format(mesh.ne))
for k in range(1000):
Setup()
print("k = {} ".format(k))
As the iterations progress, even though the number of mesh elements used each time remains consistent, the memory usage of the program continues to increase. del phi_old dosen’t work.
I found a similar post in this forum, but it also cause memory leak.
memory_leak.py (468 Bytes)
