Meshing error when using prismatic layers
I’m using OCC to construct 3D geometries, and I’d like to apply prismatic layers to selected boundaries. While testing this, I’ve noticed an issue when combining boundary renaming with boolean operations. Specifically, if I rename a boundary and use an operator such as + (union), - (difference), or * (intersection), the meshing step fails.
Either operation on its own works fine. I can rename boundaries without boolean operations, or I can use boolean operations without renaming, and the mesh is generated correctly. However, doing both together consistently causes a meshing error.
As a temporary workaround, I’m currently meshing the geometry without renaming the boundaries and then modifying the boundary names after the mesh has been created. I was wondering whether there is a more robust solution to this within the NGSolve toolchain.
I’ve attached a small script below that reproduces the issue.
Thank you in advance for any advice.
from netgen.meshing import BoundaryLayerParameters
from pathlib import Path
# Configuration flags
replace_bc = True
quarter_geom = False
using_substraction = False
using_intersection = True
L = 1
# Define geometries
box = Box(Pnt(-L, -L, -L), Pnt(L, L, L))
inner_box = Box(Pnt(-0.5*L, -0.5*L, -0.5*L), Pnt(0.5*L, 0.5*L, 0.5*L))
quarter = Box(Pnt(0, 0, -2*L), Pnt(2*L, 2*L, 2*L))
three_quarter = Box(Pnt(-2*L, -2*L, -2*L), Pnt(2*L, 2*L, 2*L)) - quarter
# Set materials and boundary conditions
quarter.mat("quarter")
quarter.bc("cut")
box.mat("outer_box")
box.bc("outer")
inner_box.mat("inner_box")
inner_box.bc("inner_bc1")
if replace_bc:
    inner_box.faces.Min(Z).name = "inner_bc2"
    inner_box.faces.Max(Z).name = "inner_bc2"
box = box - inner_box
if quarter_geom:
    if using_substraction:
        box_quarter = box - three_quarter
        inner_box_quarter = inner_box - three_quarter
    elif using_intersection:
        box_quarter = box * quarter
        inner_box_quarter = inner_box * quarter
    object3D = Glue([box_quarter, inner_box_quarter])
    object3D = Glue([box, inner_box])
geometry = OCCGeometry(object3D)
# Boundary layer parameters
B = BoundaryLayerParameters(boundary="inner_bc1", thickness=[0.1], domain="inner_box")
# Generate mesh
ngmesh = geometry.GenerateMesh(boundary_layers=[B])
print("The mesh has", mesh.ne, "elements")
# Save mesh
file_path = Path().absolute()
mesh_save_path = Path(file_path) / "meshes"
mesh_save_path.mkdir(parents=True, exist_ok=True)
mesh.ngmesh.Save(str(Path(mesh_save_path) / "meshvol.vol"))
print("Mesh exported")
print("Replaced boundary condition names?:", replace_bc)
print("Quarter geometry used?:", quarter_geom)
Hi, I do not get any errors running your script and the mesh looks ok.
Are you on the newest ngsolve release?
Hello Christopher,
Thank you for the response.
I am currently running ngsolve version 6.2.2506.
To replicate the error, the flags must be set to:
replace_bc = True
quarter_geom = True
In the code I linked above, they are set to:
replace_bc = True
Thank you.
