Hello, I’m looking for the way to intersect overlapped particles.
Here is an illustration for description.
Currently, I generate the particle A and B (considering overlapped part, 100% A and 80-90% B, I think).
What I really want to do is “Right image” (overlapped parts are assigned to both A and B).
If I generate the particles with “Union” feature, I cannot differentiate which one is A or B.
I want to Particle A and Particle B as separated domains, and intersected interface between them.
Can you tell me which part in my code should be modified for what I want?
For your information, I wrote down my code and attached some text files.
# Two particles
The constructive solid geometry (CSG) format allows to define geometric primitives such as
spheres and cylinders and perform to boolean operations on them.
import time
from netgen.csg import *
from netgen.meshing import *
import netgen.gui
from ngsolve import ngsglobals
ngsglobals.msg_level = 2
# Generate brick and mesh it
geo1 = CSGeometry()
cube = OrthoBrick( Pnt(0,0,0), Pnt(64,64,64) )
geo1.Add(cube)
m1 = geo1.GenerateMesh (meshsize.moderate, maxh=5)
# m1.Refine()
# Read Coordinates_XYZ_P1, AxisLength_abc_P1, and Euler Angles from *.txt files.
Coordinates_XYZ_P1 = np.loadtxt("outputs/PackingAlgorithm/Centroid_P1.txt")
Coordinates_XYZ_MO_P1 = np.loadtxt("outputs/PackingAlgorithm/Coordinates_XYZ_MO_P1.txt")
AxisLength_abc_P1 = np.loadtxt("outputs/PackingAlgorithm/AxisLength_P1.txt")
Periodicity_O_P1 = np.loadtxt("outputs/PackingAlgorithm/Periodicity_O_P1.txt")
Periodicity_MO_P1 = np.loadtxt("outputs/PackingAlgorithm/Periodicity_MO_P1.txt")
Coordinates_XYZ_P2 = np.loadtxt("outputs/PackingAlgorithm/Centroid_P2.txt")
Coordinates_XYZ_MO_P2 = np.loadtxt("outputs/PackingAlgorithm/Coordinates_XYZ_MO_P2.txt")
AxisLength_abc_P2 = np.loadtxt("outputs/PackingAlgorithm/AxisLength_P2.txt")
Periodicity_O_P2 = np.loadtxt("outputs/PackingAlgorithm/Periodicity_O_P2.txt")
Periodicity_MO_P2 = np.loadtxt("outputs/PackingAlgorithm/Periodicity_MO_P2.txt")
# Make Ellipsoids based on given information
t0_start = time.time()
geo2 = CSGeometry()
# Ellipsoids from original coordinates
ellips_O_P1 = [0] * len(Coordinates_XYZ_P1[:,0])
for i in range(0,len(ellips_O_P1)):
# Pnt -> Center point, Vec -> Half of Axis Length
ellips_O_P1[i] = Ellipsoid(Pnt(Coordinates_XYZ_P1[i,0],Coordinates_XYZ_P1[i,1],Coordinates_XYZ_P1[i,2]),
Vec(AxisLength_abc_P1[i,0],0,0),
Vec(0,AxisLength_abc_P1[i,1],0),
Vec(0,0,AxisLength_abc_P1[i,2]))
ellips_O_P2 = [0] * len(Coordinates_XYZ_P2[:,0])
for i in range(0,len(ellips_O_P2)):
ellips_O_P2[i] = Ellipsoid(Pnt(Coordinates_XYZ_P2[i,0],Coordinates_XYZ_P2[i,1],Coordinates_XYZ_P2[i,2]),
Vec(AxisLength_abc_P2[i,0],0,0),
Vec(0,AxisLength_abc_P2[i,1],0),
Vec(0,0,AxisLength_abc_P2[i,2]))
# Ellipsoids from matched coordinates
ellips_MO_P1 = [0] * len(Coordinates_XYZ_MO_P1)
for i in range(0,len(ellips_MO_P1)):
ellips_MO_P1[i] = Ellipsoid(Pnt(Coordinates_XYZ_MO_P1[i,0], Coordinates_XYZ_MO_P1[i,1], Coordinates_XYZ_MO_P1[i,2]),
Vec(AxisLength_abc_P1[int(Coordinates_XYZ_MO_P1[i,3]),0],0,0),
Vec(0,AxisLength_abc_P1[int(Coordinates_XYZ_MO_P1[i,3]),1],0),
Vec(0,0,AxisLength_abc_P1[int(Coordinates_XYZ_MO_P1[i,3]),2]))
ellips_MO_P2 = [0] * len(Coordinates_XYZ_MO_P2)
for i in range(0,len(ellips_MO_P2)):
ellips_MO_P2[i] = Ellipsoid(Pnt(Coordinates_XYZ_MO_P2[i,0], Coordinates_XYZ_MO_P2[i,1], Coordinates_XYZ_MO_P2[i,2]),
Vec(AxisLength_abc_P2[int(Coordinates_XYZ_MO_P2[i,3]),0],0,0),
Vec(0,AxisLength_abc_P2[int(Coordinates_XYZ_MO_P2[i,3]),1],0),
Vec(0,0,AxisLength_abc_P2[int(Coordinates_XYZ_MO_P2[i,3]),2]))
# Ellipsoids for Periodicity_O
ellips_Periodicty_O_P1 = [0] * len(Periodicity_O_P1)
for i in range(0,len(ellips_Periodicty_O_P1)):
ellips_Periodicty_O_P1[i] = Ellipsoid(Pnt(Periodicity_O_P1[i,0],Periodicity_O_P1[i,1],Periodicity_O_P1[i,2]),
Vec(AxisLength_abc_P1[int(Periodicity_O_P1[i,3]),0],0,0),
Vec(0,AxisLength_abc_P1[int(Periodicity_O_P1[i,3]),1],0),
Vec(0,0,AxisLength_abc_P1[int(Periodicity_O_P1[i,3]),2]))
ellips_Periodicty_O_P2 = [0] * len(Periodicity_O_P2)
for i in range(0,len(ellips_Periodicty_O_P2)):
ellips_Periodicty_O_P2[i] = Ellipsoid(Pnt(Periodicity_O_P2[i,0],Periodicity_O_P2[i,1],Periodicity_O_P2[i,2]),
Vec(AxisLength_abc_P2[int(Periodicity_O_P2[i,3]),0],0,0),
Vec(0,AxisLength_abc_P2[int(Periodicity_O_P2[i,3]),1],0),
Vec(0,0,AxisLength_abc_P2[int(Periodicity_O_P2[i,3]),2]))
# Ellipsoids for Periodicity_MO
# Exclude overlapped elements based on Periodicity_O_P1 and Periodicity_O_P2
ellips_Periodicty_MO_P1 = [0] * len(Periodicity_MO_P1)
for i in range(0,len(ellips_Periodicty_MO_P1)):
ellips_Periodicty_MO_P1[i] = Ellipsoid(Pnt(Periodicity_MO_P1[i,0],Periodicity_MO_P1[i,1],Periodicity_MO_P1[i,2]),
Vec(AxisLength_abc_P1[int(Periodicity_MO_P1[i,3]),0],0,0),
Vec(0,AxisLength_abc_P1[int(Periodicity_MO_P1[i,3]),1],0),
Vec(0,0,AxisLength_abc_P1[int(Periodicity_MO_P1[i,3]),2]))
ellips_Periodicty_MO_P2 = [0] * len(Periodicity_MO_P2)
for i in range(0,len(ellips_Periodicty_MO_P2)):
ellips_Periodicty_MO_P2[i] = Ellipsoid(Pnt(Periodicity_MO_P2[i,0],Periodicity_MO_P2[i,1],Periodicity_MO_P2[i,2]),
Vec(AxisLength_abc_P2[int(Periodicity_MO_P2[i,3]),0],0,0),
Vec(0,AxisLength_abc_P2[int(Periodicity_MO_P2[i,3]),1],0),
Vec(0,0,AxisLength_abc_P2[int(Periodicity_MO_P2[i,3]),2]))
# Store all ellipsoids.
all_ellips_P1 = ellips_O_P1[0]
all_ellips_P2 = ellips_O_P2[0]
# Modifying the number of elliposids which you want.
for i in range(1,len(ellips_O_P1)):
all_ellips_P1 = all_ellips_P1 + ellips_O_P1[i]
all_ellips_P1 = all_ellips_P1 + ellips_MO_P1[i]
all_ellips_P1 = all_ellips_P1 + ellips_Periodicty_O_P1[i]
all_ellips_P1 = all_ellips_P1 + ellips_Periodicty_MO_P1[i]
for i in range(1,len(ellips_O_P2)):
all_ellips_P2 = all_ellips_P2 + ellips_O_P2[i]
all_ellips_P2 = all_ellips_P2 + ellips_MO_P2[i]
all_ellips_P2 = all_ellips_P2 + ellips_Periodicty_O_P2[i]
all_ellips_P2 = all_ellips_P2 + ellips_Periodicty_MO_P2[i]
# Intersection between all ellipsoids and cube.
Partial_P1 = all_ellips_P1 * cube
Partial_P2 = all_ellips_P2 * cube
Partial_P2 = Partial_P2 - Partial_P1
# Add components for meshing.
geo2.Add(cube-(Partial_P1+Partial_P2))
geo2.Add(Partial_P1)
geo2.Add(Partial_P2)
m2 = geo2.GenerateMesh (meshsize.moderate)
t0_end = time.time()
print("Making ellipsoids took --- %s seconds ---" % (t0_end - t0_start))
t1_start = time.time()
# Need a NGSolve mesh for visualization.
import ngsolve
mesh = ngsolve.Mesh(m2)
t1_end = time.time()
print("GenerateMesh took --- %s seconds ---" % (t1_end - t1_start))
PackingAlgorithm.zip (8.8 KB)
