Hello everyone!
I have a question about the precision or tolerance of mesh generation. I believe there’s a tolerance used to generate a mesh, meaning if the distance between two points is smaller than the tolerance, NGSolve considers them as a single point in the mesh, even if there are two distinct points defined in the geometry. Is there a way to change this tolerance?
Thanks, and have a great day!
