Alternatively, it would also work to solve a PDE on the boundary elements of a 2d-mesh, can this be done with an H^1 space defined on the boundary, only?
Hi Christopher,
thanks for your reply. However, the following code
#import netgen.gui
import ngsolve as ng
from netgen.meshing import *
pnts =[(0,0), (1,0), (0.5,1)]
p1,p2,p3 = [geo.AppendPoint(*pnt) for pnt in pnts]
curves = [[["line",p1,p2],"e1"],
[["line",p2,p3],"e2"],
[["line",p3,p1],"e3"]]
[geo.Append(c,bc=bc) for c,bc in curves]
mesh = ng.Mesh(geo.GenerateMesh(maxh=0.1))
fesext = H1(mesh, order=1, definedon="e1")
gfue = GridFunction(fesext)
u, v = fesext.TnT()
a = BilinearForm(fesext, symmetric=True)
a += grad(u).Trace()*grad(v).Trace()*ds
# a += grad(u)*grad(v)*dx # yields same result
f = LinearForm(fesext)
f += 1*v*ds
gfue.vec.data = a.mat.Inverse(fesext.FreeDofs()) * f.vec
print(gfue.vec)
yields a zero vector as outcome, also f.vec is only zeros. Am I overlooking something or do I need to chose a different space?
Follow up: Is there an easy way to visualize the results? Previously, I was using
pnts_vals = [ (x,gfue(x)) for x in pnts if ngsmesh.Contains(x)]
pnts,vals = zip(*pnts_vals)
Can I constrain/restrict that to the boundary part “e1” (in my example)? I tried
for el in ngmesh.Elements1D():
print(ngmesh.GetBCName(el.index-1))
for vert in el.vertices:
print("val at " + str(ngmesh[vert]) + " is " + str(gfue(ngmesh[vert][0],ngmesh[vert][1],ngmesh[vert][2])))
