Mini element in 3D
I konw that the syntax for 2D mini element is:
velocity = VectorH1(mesh,order = 1)
velocity.SetOrder(TRIG,3)   # mini elements
velocity.Update()
pressure = H1(mesh,order = 1)
How about the right syntax for 3D mini element in Ngsolve? Are they same or not? many thanks!
yes, except you need
velocity.SetOrder(TET,4)
at least it should work like this, don’t know if someone has tried it out.
For 3D NS equations,
I tried
the codes will break down after several time steps.
I don’t know reasons. I guess this syntax add exact one 4th order polynomial in the interior of tetrahedral element.
However, I found
is stable, can I understand it as adding a bubble function for each face of terahedral elements? Since each face just is a 2D domain.
what do you mean with break down ?
Maybe you first do some tests with Stokes before moving to Navier-Stokes,
Sorry, I made mistakes due to coarse mesh(radius = 0.3; maxh = 0.1) for Cylinder 3D tube domain.
BUT,
When radius = 0.3, maxh = 0.05;
I followed your advice to test Transient Stokes. I find the results for BOTH
are same & good.
SO, does it mean both them are correct?
is stable,
while
needs conditions on the mesh, but this seems non-trivial to me.
Also in terms of matrix entries (and static condensation), the volume bubble is advantageous.
Hello, it appears that the “Set” method of functions in 3D Mini element space is yielding unexpected “nan” values. Please refer to the example below, where the output is:
2031 nan in u_mini
   0 nan in u_p1
The version of ngsolve used is NGSolve-6.2.2305.
from netgen.occ import OCCGeometry, Box
geo = OCCGeometry(Box((0,0,0), (1, 1, 1)))
V1 = VectorH1(mesh, order=1)
V2 = VectorH1(mesh, order=1)
V2.SetOrder(TET, 4)
V2.Update()
u = CF((x, y, z))
u_p1 = GridFunction(V1)
u_mini = GridFunction(V2)
u_p1.Set(u)
u_mini.Set(u)
print(f"{len(np.where(np.isnan(u_mini.vec))[0]):4d} nan in u_mini")
print(f"{len(np.where(np.isnan(u_p1.vec))[0]):4d} nan in u_p1")
