Netgen DLL problem on fresh Windows 11 VM
I’ve just run a fresh Windows 11 VM, installed python 3.12.4 from Microsoft Store,
installed netgen with pip install --upgrade ngsolve and added
C:\Users\User\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\Scripts
to the PATH environment variable, but netgen cannot start because of the following error:
C:\Users\User>netgen
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "C:\Users\User\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\Scripts\netgen.exe\__main__.py", line 4, in <module>
  File "C:\Users\User\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\site-packages\netgen\__init__.py", line 98, in <module>
    from pyngcore import Timer
  File "C:\Users\User\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\site-packages\pyngcore\__init__.py", line 1, in <module>
    from .pyngcore import *
ImportError: DLL load failed while importing pyngcore: A dynamic link library (DLL) initialization routine failed.
Is there something I am missing?
Thanks,
Stenio
Do you have any news about this issue? Something is definitively not working as expected if the software cannot work on a fresh virtual machine, don’t you agree?
This is not a real fix but as far as I know the python from the microsoft store has some weird installation behaviour… Does it work if python is installed from the python website?
I’ve just tried with a new VM:
  1. installed python 3.12.4 from www.python.org
  1. from a non administrative prompt
  2. and then
    netgen
Unfortunatelly I got the same error. :weary:
No, it doesn’t. Please, see my previous post.
Thanks
I tried also with python 3.13 and 3.11, but I got the same error.
Seems to me that there is a problem on the package pyngcore.
This is the free VM that I used: Oracle Virtual Box.
Ah I think I could just reproduce the problem. Can you try installing vcruntime?
Hi Christopher, sorry for the delay. The virtual machine comes with the runtime already installed:
Thanks,
Stenio
can you load the pyngcore library into this dependency walker to see which libs it is missing?
https://lucasg.github.io/Dependencies/
Sure. Here it is:
python should be fine, this should be there at runtime. Can you find where ngcore.dll was installed to from pip? And also the path to the pyngcore.dll
Hi Christopher,
ngcore.dll is here:
I can’t find pyngcore.dll. I have pyngcore.cp312-win_amd64.pyd in C:\Users\User\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\site-packages\pyngcore instead.
I fixed the missing modules adding their directories to %PATH%:
but still I get:
C:\Users\User>netgen Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "C:\Users\User\AppData\Local\Programs\Python\Python312\Scripts\netgen.exe\__main__.py", line 4, in <module> File "C:\Users\User\AppData\Local\Programs\Python\Python312\Lib\site-packages\netgen\__init__.py", line 98, in <module> from pyngcore import Timer File "C:\Users\User\AppData\Local\Programs\Python\Python312\Lib\site-packages\pyngcore\__init__.py", line 1, in <module> from .pyngcore import * ImportError: DLL load failed while importing pyngcore: A dynamic link library (DLL) initialization routine failed.
I made some progress setting the environment variable PYTHONPATH:
C:\Users\User>echo %PYTHONPATH%
C:\Users\User\AppData\Local\Programs\Python\Python312\Lib\site-packages\pyngcore;C:\Users\User\AppData\Local\Programs\Python\Python312\Lib\site-packages\netgen;C:\Users\User\AppData\Local\Programs\Python\Python312\Scripts;
C:\Users\User>echo %PATH%
C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\Microsoft SQL Server\150\Tools\Binn\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn\;C:\Program Files\dotnet\;C:\Users\User\AppData\Local\Programs\Python\Python312\Scripts\;C:\Users\User\AppData\Local\Programs\Python\Python312\;C:\Users\User\AppData\Local\Programs\Python\Launcher\;C:\Users\User\AppData\Local\Microsoft\WindowsApps;C:\Users\User\AppData\Local\Programs\Python\Python312\Scripts;C:\Users\User\AppData\Local\Programs\Python\Python312\Lib\site-packages\netgen;C:\Users\User\AppData\Local\Programs\Python\Python312;
    spec = importlib.util.spec_from_file_location(os.path.basename(f), os.path.abspath(f))
I’ve reinstalled python 3.12 and the path now are
C:\Users\User\AppData\Local\Programs\Python\Python312\Lib\site-packages\pyngcore and
The result is the same.
Perhaps the real problem is the absence of the pyngcore.dll file.
My friend has the same problem right now.
Were there any advances on this issue?
Thanking you in advance for your kind help,
Vincent
I had this problem too on my computer running Windows Server 2019. Downgrading to version 6.2.2402 solved the problem using
pip install ngsolve==6.2.2402
I had a similar problem after installing 6.2.2403, 6.2.2404.
Thank you for the info, I had the same issue, with version 6.2.2402, I can at least import ngsolve.
However, I still have issues with using some commands.
I tried some basic code for meshing, as described in (4.3 Working with meshes — NGS-Py 6.2.2405 documentation), but I couldn’t use the draw command.
resulted in the Kernel crashing
import ngsolve
ngsolve.webgui.Draw(mesh)
results in AttributeError: module ‘ngsolve’ has no attribute ‘webgui’
Did you ever encounter any similar issues?
Could it be a compatibility issue because I am using a different Version of Python or other packages?
Thank you very much, it worked for him!
Vincent
