I have some geometry with some line embedded in surface (2D) or surface embedded in volume (3D).
Does Netgen also support this kind of features? Is there any one can share some examples?
In Gmsh, these embedded geometry can be defined as follows:
1 /*********************************************************************
2 *
3 * Gmsh tutorial 15
4 *
5 * Embedded points, lines and surfaces
6 *
7 *********************************************************************/
8
9 // We start one again by including the first tutorial:
10 Include "t1.geo";
11
12 // We change the mesh size to generate coarser mesh
13 lc = lc * 4;
14 Characteristic Length {1:4} = lc;
15
16 // We define a new point
17 Point(5) = {0.02, 0.02, 0, lc};
18
19 // One can force this point to be included ("embedded") in the 2D mesh, using
20 // the "Point In Surface" command:
21 Point{5} In Surface{1};
22
23 // In the same way, one can force a curve to be embedded in the 2D mesh using
24 // the "Line in Surface" command:
25 Point(6) = {0.02, 0.12, 0, lc};
26 Point(7) = {0.04, 0.18, 0, lc};
27 Line(5) = {6, 7};
28 Line{5} In Surface{1};
29
30 // One can also embed points and lines in a volume using the "Line/Point In
31 // Volume" commands:
32 Extrude {0, 0, 0.1}{ Surface {1}; }
33
34 p = newp;
35 Point(p) = {0.07, 0.15, 0.025, lc};
36 Point{p} In Volume {1};
37
38 l = newl;
39 Point(p+1) = {0.025, 0.15, 0.025, lc};
40 Line(l) = {7, p+1};
41 Line{l} In Volume {1};
42
43 // Finally, one can also embed a surface in a volume using the "Surface In
44 // Volume" command:
45 Point(p+2) = {0.02, 0.12, 0.05, lc};
46 Point(p+3) = {0.04, 0.12, 0.05, lc};
47 Point(p+4) = {0.04, 0.18, 0.05, lc};
48 Point(p+5) = {0.02, 0.18, 0.05, lc};
49 Line(l+1) = {p+2, p+3};
50 Line(l+2) = {p+3, p+4};
51 Line(l+3) = {p+4, p+5};
52 Line(l+4) = {p+5, p+2};
53 ll = newll;
54 Line Loop(ll) = {l+1:l+4};
55 s = news;
56 Plane Surface(s) = {ll};
57 Surface{s} In Volume{1};
Thanks,
Bin
Attachment: t15.geo
Attachment: t1.geo
