Hello everyone! I’m trying to automate a simple meshing procedure, that I follow using Netgen’s GUI, into a Python script.
The GUI procedure is as follows:
- “File → Import Mesh” to import an STL file [a closed surface]
- “Generate Mesh”
- “Optimize Volume”
- “Export Mesh”
Now, my current script looks like this:
[code]import netgen.meshing as meshing
m = meshing.ImportMesh(“surfaceMesh.stl”)
m.GenerateVolumeMesh()
m.OptimizeVolumeMesh(meshing.MeshingParameters())
m.Export(“volumeMesh.gmsh”, “Gmsh Format”)
[/code]
The problem is that the mesh generated by the steps above is different from the mesh generated by this script, and in particular the one generated by my script has much worse quality [aspect ratio].
My understanding was that, by passing a new meshing.MeshingParameters()
instance, Netgen would use the default parameters, which I assumed were also the ones used by the GUI, but it looks like this is not the case.
Can anyone point me in the right direction? I get a very good mesh using the GUI procedure, and I want to reproduce it exactly with my script.
Thanks for any help!
Massimiliano
you can get the default meshing parameters by using the meshsize
object.
m.OptimizeVolumeMesh(meshsize.moderate)
There are also the other default GUI options like meshsize.coarse
Hello Christopher, thanks for your reply!
I tried following your advice, now my script looks like so:
m.GenerateVolumeMesh(meshing.meshsize.moderate)
m.OptimizeVolumeMesh(meshing.meshsize.moderate)
m.Export(“volumeMesh0S.gmsh”, “Gmsh Format”)
[/code]
I can confirm that I get the same mesh after step 2 in the GUI [“Generate Mesh”] and after calling m.GenerateVolumeMesh(meshing.meshsize.moderate)
. However, I get two different meshes after step 3 [“Optimize Volume”] and after running m.OptimizeVolumeMesh(meshing.meshsize.moderate)
. In particular, the script command changes the mesh only very little [removes around 300 nodes and doesn’t change the quality at all] while the GUI procedure removes 18’000 nodes and significantly improves the mesh quality.
What else can I try?
Thanks a lot for your help!
Massimiliano
To add to the information above, I compared the output I get, in the terminal, when running Netgen via GUI with the output I get when running via Python.
The two outputs are identical for the meshing part, but when the volume optimisation starts, the GUI outputs this
Volume Optimization
CombineImprove
2221828 edges
126 edges with improvement
108 elements combined
ImproveMesh
Total badness = 2.72533e+06
Total badness = 2.72509e+06
SplitImprove
2220957 edges
4 edges with improvement
2 splits performed
0 elements split
ImproveMesh
Total badness = 2.72633e+06
Total badness = 2.72613e+06
SwapImprove
83805 swaps performed
SwapImprove2
89 swaps performed
ImproveMesh
Total badness = 2.48466e+06
Total badness = 2.41983e+06
... Lots of other text
while from the Python script I get
Volume Optimization
CombineImprove
2221828 edges
ImproveMesh
SplitImprove
2220957 edges
2 splits performed
0 elements split
ImproveMesh
SwapImprove
5 swaps performed
SwapImprove2
0 swaps performed
ImproveMesh
Total badness = 2.72612e+06
Total badness = 2.72609e+06
You can see that the output from the GUI says, for the SwapImprove step, 83805 swaps performed
, while the Python script gives 5 swaps performed
Is this any helpful? What influences that number?
