Newton Stopping criteria
I am trying to implement a Newton method with the stopping criterium as the l2 norm of the residual from the non-linear form. However, when the norm of the residual is computed in each iteration
a.Apply(gfu.vec, res) print("\t||res||_l2 = {:}".format(sqrt(InnerProduct(res,res))))
this does not converge to zero, even though the method converges (in the dual norm) and the update disappears. I have attached a MWE, (minimal adaptation of the iTutorial 3.7 on Nonlinear Problems).
As we are trying to solve a(u[sub]h[/sub],v[sub]h[/sub])=0, the residual ||a(u[sub]h[/sub][sup]i[/sup], v[sub]h[/sub]) ||[sub]l2[/sub] = ||res ||[sub]l2[/sub] should converge towards zero. Doe anyone know, what is going wrong here?
Best wishes,
Henry
Attachment: NewtonResiualMWE.py
Hi Henry,
The application of the bilinearform does not care about dirichlet dofs. Hence, your res-vector may have (has) non-zero entries which however have no impact on your iterate. This is what you see in your MWE. You should Project the dirichlet dofs out.
Thank you Christoph!
Is there a better way for projecting out the Dirichlet Dofs than going for
res.FV().NumPy()[V.FreeDofs()]
Best wishes,
Henry
You can use the Projector object. You provide a BitArray (in your case the freedofs-array) and a flag true/false. The result is a linear operator (basematrix). You can then apply the projector on a vector as any other basematrix object. The result will set the entries to zero wherever the BitArray is true/flase (depending on the flag you provided).
Thank you! I wasn’t aware of this object before. Using the projector has also resulted in the whole script running slightly faster :slight_smile: !
Best wishes,
Henry
