Ngsolve_special_functions
I tried to install ngsolve_special_functions following your advice here and after downloading the latest version of the special functions library. I ran
cmake .. -DNGSolve_DIR=/Library/Frameworks/Python.framework/Versions/3.14/lib/python3.14/site-packages/ngsolve/cmake -DNetgen_DIR=/Library/Frameworks/Python.framework/Versions/3.14/lib/python3.14/site-packages/netgen/cmake -DCMAKE_POLICY_VERSION_MINIMUM=3.5
and all appeared to go well. But when I ran
netgen gammaln.py
I got a bunch of error messages culminating in
File “/Users/monk/Desktop/ngs-special-functions/demo/gammaln.py”, line 8, in
import ngsolve.special_functions
ModuleNotFoundError: No module named ‘ngsolve.special_functions’
Can someone help me to get Netgen to see the special functions module?
Thanks
Peter
Hi Peter,
did you install the module with
make install
there at the end it should say something:
Installing: /path/to/ngsolve_special_functions.so
this path needs to be in your PYTHONPATH for the so to be found
ah I just saw in my case the module is called
ngsolve_special_functions not ngsolve.special_functions. Does it work if you rename This in the python file?
Thanks Christopher! Yes it works perfectly after setting PYTHONPATH and changing the module name.
Peter
