tengen
July 28, 2022, 1:06pm
1
I am at the step make install in the build from source instructions.
I am getting:
CMake Error at python/cmake_install.cmake:71 (file):
file INSTALL cannot find
“/home/vlatko/ngsuite/ngsolve-build/ngsolve/python/…/stubs/ngsolve-stubs”:
No such file or directory.
cmake_install.cmake:96 (include)
Can anyone help me with this?
hvwahl
August 1, 2022, 1:39pm
2
Hello tengen,
maybe try setting -DBUILD_STUB_FILES=OFF in the cmake options.
Best wishes,
Henry
tengen
August 3, 2022, 9:34am
3
That has worked, thank you.
Although this doesn’t solve the problem but is just a work around. Do you have any idea how to solve this issue?
I know that stubs are usually used with testing and for that matter, I can use the flag you suggested. But still this error should not appear.
the stubs are just for auto completion in editors. You can also call pybind11-stubgen manually to create them and just copy them to the python installation dir if you want autocompletion.
For some help in pybind11-stubgen see here GitHub - sizmailov/pybind11-stubgen: Generates stubs for python modules (targeted to C++ extensions compiled with pybind11)
