ngsolve:ngxfem:The failure regarding the implementation of dtref(u.Trace()) )
Thank you to the developers of the ngsolve program for providing such a valuable learning platform. Due to the presence of time derivatives in the boundary terms of the equation, it is necessary to implement dtref at the boundaries. However, an error was encountered in doing so:Operator “dt” does not exist for CompoundFESpace!,Despite various attempts, the endeavor still ended in failure.I am very grateful for the guidance provided by the ngsolve team members.
main equation:
main code:
Space finite element order
order = 1
Time finite element order
k_t = 2
Final simulation time
tend = 1.0
Time step
sizeh=4
PDE parameter
Diff_CF=0.02
Delta=0.02
Sigma=1
Diff_Gamma_CF=0.02
Delta_Gamma=0.02
k=1
delta_t = 1 / 2**(sizeh)
T_time=np.arange(0,1+delta_t ,delta_t )
geo.AddRectangle( (0, 0), (1, 1), bc = “outer”)
mesh = Mesh( geo.GenerateMesh(maxh=1/2**sizeh))
Normal=specialcf.normal(mesh.dim)
TLen=len(T_time)
def dt(u):
return 1.0 / delta_t * dtref(u)
told = Parameter(0)
t = told + delta_t * tref
dxt = delta_t * dxtref(mesh, time_order=8)
dst=delta_t*dxtref(mesh,time_order=8,definedon=‘mesh.Bounderies(outer)’)
Fan_Space=H1(mesh,order=1)
Mu_Space=H1(mesh,order=1)
Mu_Gamma_Space=Compress(H1(mesh,order=1,definedon=mesh.Boundaries(‘outer’)))
tfe = ScalarTimeFE(k_t) # type: ignore
ST_Fan=tfeFan_Space
ST_Mu=tfe
Mu_Space
ST_Mu_Gamma=tfe*Mu_Gamma_Space
fes=ST_FanST_MuST_Mu_Gamma
(Fan,Mu,Mu_Gamma),(theta1,theta2,theta3)=fes.TnT()
mass_Fan=np.zeros(TLen-1)
mass_Fan_Gamma=np.zeros(TLen-1)
H1_Err_Phi=np.zeros(TLen-1)
gfu_iter=GridFunction(fes)
Init_Fan=GridFunction(Fan_Space)
potential function second derive
def Doub_second(u):
return 3*u**2-1
def Doub_First(u):
return u**3-u
a_Lin=BilinearForm(fes)
the fan not the origin fan fan1=fan^{n-1}+(t-t_{n-1})fan
a_Lin+=Fantheta1dxt+delta_ttrefdt(Fan)theta1dxt+Diff_CFgrad(Mu)grad(theta1)dxt
+Fan.Trace()theta3dst+delta_t
tref
dt(Fan.Trace())theta3dst#+Diff_Gamma_CF
grad(Mu_Gamma).Trace()grad(theta3).Trace()dst
#-Mu
theta2
dxt-Mu_Gammatheta2.Trace()dst
#+delta_t
tref
DeltaSigmagrad(Fan)grad(theta2)dxt+delta_ttrefDelta_Gammakgrad(Fan).Trace()grad(theta2).Trace()dst
#+1/Delta
Sigma
delta_ttrefDoub_second(Init_Fan+delta_ttrefgfu_iter.components[0])Fantheta2dxt
#+1/Delta_Gamma**delta_t
trefDoub_second(Init_Fan+delta_ttrefgfu_iter.components[0])Fantheta2dst
        Best regards
        ChLun Ye
Sorry for not replying to this message, but perhaps you can explain what you are aiming at and minimize your example?
It seems you try to solve a time-dependent PDE on a fitted surface? This is indeed a scenario not usually consided in ngsxfem so far. If you explain your case more clearly we could look into it more concretely.
Best, Christoph
Dear Christoph,
Thank you very much for taking the time to answer my question.
Best wishes,
ChLun
