Hi everyone,
I am trying to solve Maxwell’s eigenvalue problem in an axisymmetric domain. Here is the weak form and reference,
and here is my implementation.
from ngsolve.la import EigenValues_Preconditioner
import scipy.sparse as sp
def combine_summatrix(fes, S):
S_scipy_mat_full = None
for ii, s in enumerate(S):
rows,cols,vals = s.COO()
if ii == 0:
S_scipy_mat_full = sp.csr_matrix((vals,(rows,cols)))
S_scipy_mat_full += sp.csr_matrix((vals,(rows,cols)))
hfull, wfull = S_scipy_mat_full.shape
S_scipy_mat_coo = S_scipy_mat_full.tocoo()
ngs_mat = S[0].CreateMatrix()
Scomb = ngs_mat.CreateFromCOO(S_scipy_mat_coo.row, S_scipy_mat_coo.col, S_scipy_mat_coo.data, hfull, wfull)
return Scomb
mu0 = 4 * pi * 1e-7
eps0 = 8.85418782e-12
c0 = 299792458
rect = Rectangle(200e-3, 300e-3).Face()
rect.edges[0].name = "bottom"
rect.edges[1].name = "right"
rect.edges[2].name = "top"
rect.edges[3].name = "left"
geo = OCCGeometry(rect, dim=2)
mesh = Mesh(geo.GenerateMesh(maxh=50e-3))
# Draw(mesh)
r = y # radial coordinate on 2D meridian
m = 0
def a1(arg1, arg2):
return r * curl(arg1)*curl(arg2)*dx
def a2(arg1, arg2):
return 1/r*arg1*arg2*dx
def a3(arg1, arg2):
return (arg1*grad(arg2) + 1/r*arg1[1]*arg2)*dx
def a4(arg1, arg2):
return 1/r*(r**2*grad(arg1)*grad(arg2) + r*grad(arg1)[1]*arg2 + r*arg1*grad(arg2)[1] + arg1*arg2)*dx
def b1(arg1, arg2):
return r*arg1*arg2*dx
def b2(arg1, arg2):
# 2) build the mixed space
order = 3
VrVz = HCurl(mesh, order=order, dirichlet="top") # (E_r,E_z)
um, vm = VrVz.TnT()
G, Vphi = VrVz.CreateGradient() #Vphi -> H1
ug, vg = Vphi.TnT()
V = VrVz * Vphi
(u, u_phi) = V.TrialFunction()
(v, v_phi) = V.TestFunction()
a = BilinearForm(a1(u, v) + a4(u_phi, v_phi) + m**2*a2(u, v) + m*a3(u, v_phi) + m*a3(v, u_phi))
b = BilinearForm(b1(u, v) + b2(u_phi, v_phi))
mc = BilinearForm(b1(um, vm))
mg = BilinearForm(b2(ug, vg))
apre = BilinearForm(a1(u, v) + a4(u_phi, v_phi) + m**2*a2(u, v) + m*a3(u, v_phi) +\
m*a3(v, u_phi) + b1(u, v) + b2(u_phi, v_phi))
pre = Preconditioner(apre, type="direct", inverse="sparsecholesky")
b.Assemble()
mc.Assemble()
mg.Assemble()
apre.Assemble()
I_VrVz = IdentityMatrix(VrVz.ndof)
I_phi = IdentityMatrix(Vphi.ndof)
GT = G.CreateTranspose()
S = combine_summatrix(Vphi, [GT @ mc.mat @ G, mg.mat])
Sinv = S.Inverse(inverse="sparsecholesky", freedofs=Vphi.FreeDofs())
lams = EigenValues_Preconditioner(S, Sinv)
print(len(lams), lams)
print(max(lams)/min(lams))
embHc, embH1 = V.embeddings
proj = embHc @ (I_VrVz - G@Sinv@GT@mc.mat) @ embHc.T +\
embH1 @ (I_phi - Sinv@mg.mat) @ embH1.T +\
embH1 @ (-Sinv@GT@mc.mat) @ embHc.T +\
embHc @ (-G@Sinv@mg.mat) @ embH1.T
# print (proj.GetOperatorInfo())
projpre = proj @ pre.mat
evals, evecs = solvers.PINVIT(a.mat, b.mat, pre=projpre, num=5, maxit=20)
freq_fes = []
# evals[0] = 1 # <- replace nan with zero
for i, lam in enumerate(evals):
freq_fes.append(c0 * np.sqrt(np.abs(lam)) / (2 * np.pi) * 1e-6)
print(freq_fes)
# plot results
gfu_E = []
gfu_H = []
for i in range(len(evecs)):
w = 2 * pi * freq_fes[i] * 1e6
gfu = GridFunction(V)
gfu.vec.data = evecs[i]
# Extract the components from the product space GridFunction
gfu_Er_Ez, gfu_Ephi = gfu.components
gfu_E.append([gfu_Er_Ez[0], gfu_Er_Ez[1], gfu_Ephi])
What I observe from the solutions:
- For modes with an azimuthal field component equal to zero (E_\phi=\bf{0}), the solution is exactly correct. For the other modes, the solution is close but not exact.
- For modes with incorrect but almost exact solutions, the eigenvalue changes ever so slightly with each run. For example, the correct frequency of the first mode is 609 MHz but my current implementation gives a value between 610 and 620 MHz in each run.
I have also attached images of the field distribution from my code and from CST studio. The first image is the field profile of the first monopole mode from CST studio and the second image is the same mode’s field profile from my code.
Best regards
