OCC Periodic Mesh of geometry with multiple shapes on the boundary faces
Hi, Im using OCC, NGsolve and right now I’m struggling with meshing problem of the periodic geometry of patterns. I need to create periodic mesh of my geometry. The utility I’m using can prepare periodic mesh under the condition that there is only one closed shape on the boundary surface. If there are more shapes, it will make a nonperiodic mesh. Could someone please advice me, if there is any way to create such a periodic mesh in OCC?
Below is my code and an example geometry, where the only one direction (Y) has a periodic faces.
Thanks :slight_smile:
def Cell50Block(nX, nY, nZ, L, r, mesh_order=2, minh=0.2, maxh=0.4):
    for i in trange(nX, desc='cells generating...'):
        for j in range(nY):
            for k in range(nZ):
                lp1x = np.array([-L/2. + L*i, L*j, L*k])
                lp2x = np.array([ L/2. + L*i, L*j, L*k])
                linex = line(lp1x, lp2x, r)
                lp1y = np.array([L*i, -L/2 + L*j, L*k])
                lp2y = np.array([L*i,  L/2 + L*j, L*k])
                liney = line(lp1y, lp2y, r)
                lp1z = np.array([L*i, L*j, -L/2 + L*k])
                lp2z = np.array([L*i, L*j,  L/2 + L*k])
                linez = line(lp1z, lp2z, r)
                if i==0 and j==0 and k==0:
                    RVE = linex + liney + linez
                    RVE += linex + liney + linez
    RVE = RVE.Move((-L*(nX-2)+1,-L*(nY-2),-L*(nZ-2)))
    RVE.faces.Min(occ.X).Identify(RVE.faces.Max(occ.X), "periodicX",
                                  IdentificationType.PERIODIC)
    RVE.faces.Min(occ.Y).Identify(RVE.faces.Max(occ.Y), "periodicY",
    RVE.faces.Min(occ.Z).Identify(RVE.faces.Max(occ.Z), "periodicZ",
    posX = occ.X >= L/2.
    negX = occ.X <= -L/2.
    posY = occ.Y >= L/2.
    negY = occ.Y <= -L/2.
    posZ = occ.Z >= L/2.
    negZ = occ.Z <= -L/2.
    RVE.faces[posX].name = 'pos_x'
    RVE.faces[posX].col = (0, 0, 1)
    RVE.faces[negX].name = 'neg_x'
    RVE.faces[negX].col = (0, 0, 1)
    RVE.faces[posY].name = 'pos_y'
    RVE.faces[posY].col = (0, 0, 1)
    RVE.faces[negY].name = 'neg_y'
    RVE.faces[negY].col = (0, 0, 1)
    RVE.faces[posZ].name = 'pos_z'
    RVE.faces[posZ].col = (0, 0, 1)
    RVE.faces[negZ].name = 'neg_z'
    RVE.faces[negZ].col = (0, 0, 1)
    # DrawGeo(RVE);
    geo = occ.OCCGeometry(RVE)
    mesh = Mesh(geo.GenerateMesh(minh=minh, maxh=maxh))
    mesh.Curve(mesh_order)
    return mesh
Can you provide a minimal example code that is not working as expected?
Surely, below is functional code and the area of interest is the function “Cell50Block()”. The mesh should be periodic in every direction, but it appears to be periodic only in the Y axis, bcs on the X and Z boundaries are multiple closed shapes (see picture abowe). Below is screenshot of periodicity check.
Again, thanks a lot for any advice :slight_smile:
import dolfin as df
import meshio
import netgen.occ as occ
import ngsolve as ng
from dolfin import near
from mpi4py import MPI
from netgen.meshing import IdentificationType
from ngsolve import Mesh
from tqdm import trange
# The indices of the full stiffness matrix of (orthorhombic) interest
Voigt_notation = [(0, 0), (1, 1), (2, 2), (1, 2), (0, 2), (0, 1)]
class ExternalCell2Dolfin(object):
    def __init__(self, mesh):
        self.mesh = mesh
        self.centre = (self.mesh.coordinates().max(
            0) + self.mesh.coordinates().min(0)) / 2
        # centering
        self.mesh.translate(df.Point(-self.centre))
        self.xmin, self.ymin, self.zmin = self.mesh.coordinates().min(0)
        self.xmax, self.ymax, self.zmax = self.mesh.coordinates().max(0)
        self.lx = self.xmax - self.xmin
        self.ly = self.ymax - self.ymin
        self.lz = self.zmax - self.zmin
        self.EPS = 1e-5
        self.get_markers()
    def get_left_corner(self):
        EPS = self.EPS
        xmin, ymin, zmin = self.xmin, self.ymin, self.zmin
        class get_corner(df.SubDomain):
            def inside(self, x, on_boundary):
                return df.near(x[0], xmin, EPS) \
                    and df.near(x[1], ymin, EPS) \
                    and df.near(x[2], zmin, EPS) and on_boundary
        return get_corner()
    def get_markers(self):
        EPS = self.EPS
        xmax, ymax, zmax = self.xmax, self.ymax, self.zmax
        class neg_x(df.SubDomain):
                return df.near(x[0], xmin, EPS) and on_boundary
        class neg_y(df.SubDomain):
                return df.near(x[1], ymin, EPS) and on_boundary
        class pos_x(df.SubDomain):
                return df.near(x[0], xmax, EPS) and on_boundary
        class pos_y(df.SubDomain):
                return df.near(x[1], ymax, EPS) and on_boundary
        class neg_z(df.SubDomain):
                return df.near(x[2], zmin, EPS) and on_boundary
        class pos_z(df.SubDomain):
                return df.near(x[2], zmax, EPS) and on_boundary
        self.boundaries = {'neg_x': neg_x(), 'pos_x': pos_x(),
                           'neg_y': neg_y(), 'pos_y': pos_y(),
                           'neg_z': neg_z(), 'pos_z': pos_z()}
    def save_mesh(self, fname="reentrant_cell.pvd"):
        file = df.File(fname)
        file << self.mesh
    def check_periodic(self):
        points = self.mesh.coordinates()
        pcs = [[self.xmin, self.xmax],
               [self.ymin, self.ymax],
               [self.zmin, self.zmax]]
        nms = ['x', 'y', 'z']
        for i in range(len(pcs)):
            pc_min, pc_max = pcs[i]
            print(f'Checking {nms[i]}-periodicity...', end=" ", flush=True)
            points_min = points[(points[:, i] >= (pc_min-self.EPS))
                                & (points[:, i] <= (pc_min + self.EPS))]
            points_max = points[(points[:, i] >= (pc_max-self.EPS))
                                & (points[:, i] <= (pc_max + self.EPS))]
            if len(points_min) == len(points_max):
                print('PASS')
                print('FAILED')
def line(point1, point2, r, cup=False):
    lp1 = occ.Sphere(occ.Pnt(point1), r=r)
    lp2 = occ.Sphere(occ.Pnt(point2), r=r)
    h = np.linalg.norm(point2-point1)
    direction = (point2-point1)/h
    line = occ.Cylinder(occ.Pnt(point1),
                        occ.gp_Vec(tuple(direction)),
                        r=r, h=h)
    if cup:
        return line + lp1 + lp2
        return line
        for j in range(nY):
            for k in range(nZ):
    return mesh
def netgen2dolfin(netgen_mesh):
    MESH_FILE_NAME = 'mesh.xdmf'
    # only linear elements
    vertices = np.array([list(v.point) for v in netgen_mesh.vertices])
    connectivity = []
    mat_ids = []
    materials = netgen_mesh.GetMaterials()
    for i, el in enumerate(netgen_mesh.Elements(ng.VOL)):
        connectivity.append([v.nr for v in el.vertices])
        mat_ids.append(0)
        for j, material in enumerate(materials):
            if el.mat == material:
                mat_ids[i] = j
    mesh = meshio.Mesh(vertices, {"tetra": connectivity},
                       cell_data={'materials': [mat_ids]})
    mesh.write(MESH_FILE_NAME)
    mesh = df.Mesh()
    with df.XDMFFile(MESH_FILE_NAME) as infile:
        infile.read(mesh)
    return mesh
if __name__ == '__main__':
    mesh = Cell50Block(1, 4, 1, 1.0, 0.15, mesh_order=1, minh=0.004, maxh=0.06)
    mesh = netgen2dolfin(mesh)
    domain = ExternalCell2Dolfin(mesh)
    domain.save_mesh('mesh.pvd')
    domain.check_periodic()
for multiple faces you need to also give all the faces and provide the trafo between the faces. Or you identify all pair separately.
faces.Min(X) only gives one minimal face (depending on numeric rounding errros which).
you can do
    minX = RVE.faces.Min(occ.X) + 1e-8
    maxX = RVE.faces.Max(occ.X) - 1e-8
    trf = gp_Transf.Translation(distance * occ.X)
    RVE.faces.RVE.faces[occ.X < minX].Identify(RVE.faces[occ.X > maxX], "periodicX",
                                  IdentificationType.PERIODIC, trf)
to identify all X faces.
and what should be the purpose of the function gp_Transf? Thanks :slight_smile:
It needs to be the transformation from the first set of faces to the second one. The faces are not necessarily ordered the same way, so we need to find the matching pairs by the transformation.
If there is only one face mapped to the other we automatically generate the transformation as a translation between the centers of the faces.
I was trying to implement your code and I’m having trouble importing gp_Transf function. Netgen doesn’t know this function, or did I miss something? Below is my code. Thank you again :slight_smile: !
import meshio
from netgen import gp_Transf
import dolfin as df
        self.mesh = mesh
        # centering
        self.EPS = 1e-5
        self.get_markers()
        EPS = self.EPS
        return get_corner()
        EPS = self.EPS
        file << self.mesh
                print('PASS')
                print('FAILED')
                        r=r, h=h)
    if cup:
        return line
        for j in range(nY):
            for k in range(nZ):
    distance = L
    epsx = occ.gp_Vec((1e-8, 0, 0))
    epsy = occ.gp_Vec((0, 1e-8, 0))
    epsz = occ.gp_Vec((0, 0, 1e-8))
    minX = RVE.faces.Min(occ.X + epsx)
    trf = occ.gp_Transf.Translation(-distance/2 * occ.X)
    minY = RVE.faces.Min(occ.Y + epsy)
    maxY = RVE.faces.Max(occ.Y - epsy)
    trf = occ.gp_Transf.Translation(-distance/2 * occ.Y)
    RVE.faces.RVE.faces[occ.Y < minY].Identify(RVE.faces[occ.Y > maxY], "periodicY",
    minZ = RVE.faces.Min(occ.Z + epsz)
    maxZ = RVE.faces.Max(occ.Z - epsz)
    trf = occ.gp_Transf.Translation(-distance/2 * occ.Z)
    RVE.faces.RVE.faces[occ.Z < minZ].Identify(RVE.faces[occ.Z > maxZ], "periodicZ",
    # RVE.faces.Min(occ.X).Identify(RVE.faces.Max(occ.X), "periodicX",
    #                               IdentificationType.PERIODIC)
    # RVE.faces.Min(occ.Y).Identify(RVE.faces.Max(occ.Y), "periodicY",
    # RVE.faces.Min(occ.Z).Identify(RVE.faces.Max(occ.Z), "periodicZ",
    return mesh
    connectivity = []
    mat_ids = []
        mat_ids.append(0)
                mat_ids[i] = j
    mesh = df.Mesh()
        infile.read(mesh)
    return mesh
the function should be in netgen.occ
Best Christopher
It seems that the function is gp_Trsf form netgen.occ. I adapted your code a little bit, as follows
    maxX = RVE.faces.Max(occ.X - epsx)
    trf = occ.gp_Trsf.Translation(-distance/2 * occ.X)
The netget.occ can’t work with defining faceses like in this code RVE.faces.RVE.faces[occ.x < minX]… Is there any way to fix this line? Or it can be fixed by for-loop for example? Below is shown error message. Thank you
--> 145 RVE.faces.RVE.faces[occ.X < minX].Identify(RVE.faces[occ.X > maxX], "periodicX",
    146                               IdentificationType.PERIODIC, trf)
AttributeError: 'netgen.libngpy._NgOCC.ListOfShapes' object has no attribute 'RVE'
ah yes sorry typo. but you having RVE.faces twice is also a typo or?
oh, i see.
But there is still problem with arguments as follows:
--> 145 RVE.faces[occ.X < minX].Identify(RVE.faces[occ.X > maxX], "periodicX",
TypeError: __lt__(): incompatible function arguments. The following argument types are supported:
    1. (self: netgen.libngpy._NgOCC.gp_Vec, arg0: float) -> netgen::DirectionalInterval
Invoked with: (1, 0, 0), <netgen.libngpy._NgOCC.Face object at 0x7377c2e32370>
in occ.X<minX the minX should be a number, but in your case it is a shape
Thank you for your prompt and significant support. I really appreciate it! I finally figure it out! Below is my code, which works for me.
    minX = -distance/2 + 1e-3
    maxX = distance/2 - 1e-3
    trf = occ.gp_Trsf.Translation(distance * occ.X)
"--> likewise for other directions"
It connects different geometries in the right way, but still has a problem with the following geometry:
The code above can create mesh with periodic faces only for 2 directions. In this case it’s not able to create X direction periodic faces. Below are the face mashes of interest in the overlay for X (not periodic) and Y (periodic) direction.
Do you have any idea what’s wrong? Again, thank you very much for your help.
To reference joachim:
I think this can be a bug, but if you post a full new minimal example that we can run, we have a change to check it :wink:
Yes, sorry. Here is the new executable code:
import meshio
from netgen.occ import gp_Trsf
import dolfin as df
        self.mesh = mesh
        # centering
        self.EPS = 1e-5
        self.get_markers()
        EPS = self.EPS
        return get_corner()
        EPS = self.EPS
        file << self.mesh
                print('PASS')
                print('FAILED')
                        r=r, h=h)
    if cup:
        return line
def Cell21X(L, r, mesh_order=2, minh=0.2, maxh=0.4):
    lp1 = np.array([- L/2., - L/2., - L/2.])
    lp2 = np.array([- L/2., + L/2., - L/2.])
    lp3 = np.array([+ L/2., + L/2., - L/2.])
    lp3out = np.array([+ L/2. + r, + L/2. + r, - L/2. - r])
    lp4 = np.array([+ L/2., - L/2., - L/2.])
    lp5 = np.array([- L/2., - L/2., + L/2.])
    lp5out = np.array([- L/2. - r, - L/2. - r, + L/2. + r])
    lp6 = np.array([- L/2., + L/2., + L/2.])
    lp7 = np.array([+ L/2., + L/2., + L/2.])
    lp8 = np.array([+ L/2., - L/2., + L/2.])
    line1 = line(lp1, lp7, r)
    line2 = line(lp2, lp8, r)
    line3 = line(lp3, lp5, r)
    line4 = line(lp4, lp6, r)
    RVE = line1 + line2 + line3 + line4
    lp_outer = occ.Box(occ.Pnt(lp3out), occ.Pnt(lp5out))
    lp_inner = occ.Box(occ.Pnt(lp3), occ.Pnt(lp5))
    GG = lp_outer-lp_inner
    RVE -= GG
    minX = -L/2 + 1e3
    maxX = L/2 - 1e-3
    trf = occ.gp_Trsf.Translation(L * occ.X)
    minY = -L/2 + 1e-3
    maxY = L/2 - 1e-3
    trf = occ.gp_Trsf.Translation(L * occ.Y)
    minZ = -L/2 + 1e-3
    maxZ = L/2 - 1e-3
    trf = occ.gp_Trsf.Translation(L * occ.Z)
    return mesh
    connectivity = []
    mat_ids = []
        mat_ids.append(0)
                mat_ids[i] = j
    mesh = df.Mesh()
        infile.read(mesh)
    return mesh
    mesh = Cell21X(1.0, 0.05, mesh_order=1, minh=0.001, maxh=0.02)
