I have installed libopenmpi2 2.1.1-8 and libopenmpi-dev 2.1.1-8 on Ubuntu 18.04. I then built NGSolve from source with USE_MPI=ON.
The py_tutorial examples are all working for me in that I can run the mpi examples like thismpirun -np 5 ngspy mpi_poisson.py
I can also run the non-mpi examples like thisnetgen poisson.py
– But I can no longer run the non-mpi examples in this way: python3 poisson.py
. If I try, I get an error like this:
[color=purple]
importing NGSolve-6.2.1902-107-g5aa0a3e4
[dow-HP-Notebook:18549] mca_base_component_repository_open: unable to open mca_patcher_overwrite: /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi/mca_patcher_overwrite.so: undefined symbol: mca_patcher_base_patch_t_class (ignored)
[dow-HP-Notebook:18549] mca_base_component_repository_open: unable to open mca_shmem_mmap: /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi/mca_shmem_mmap.so: undefined symbol: opal_show_help (ignored)
[dow-HP-Notebook:18549] mca_base_component_repository_open: unable to open mca_shmem_posix: /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi/mca_shmem_posix.so: undefined symbol: opal_shmem_base_framework (ignored)
[dow-HP-Notebook:18549] mca_base_component_repository_open: unable to open mca_shmem_sysv: /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi/mca_shmem_sysv.so: undefined symbol: opal_show_help (ignored)[/color]
[color=purple]It looks like opal_init failed for some reason; your parallel process is
likely to abort. There are many reasons that a parallel process can
fail during opal_init; some of which are due to configuration or
environment problems. This failure appears to be an internal failure;
here’s some additional information (which may only be relevant to an
Open MPI developer):
opal_shmem_base_select failed
→ Returned value -1 instead of OPAL_SUCCESS[/color]
[color=purple]It looks like orte_init failed for some reason; your parallel process is
fail during orte_init; some of which are due to configuration or
opal_init failed
→ Returned value Error (-1) instead of ORTE_SUCCESS[/color]
[color=purple]It looks like MPI_INIT failed for some reason; your parallel process is
fail during MPI_INIT; some of which are due to configuration or environment
problems. This failure appears to be an internal failure; here’s some
additional information (which may only be relevant to an Open MPI
developer):
ompi_mpi_init: ompi_rte_init failed
→ Returned “Error” (-1) instead of “Success” (0)[/color]
[color=purple]*** An error occurred in MPI_Init
*** on a NULL communicator
*** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
*** and potentially your MPI job)
[dow-HP-Notebook:18549] Local abort before MPI_INIT completed completed successfully, but am not able to aggregate error messages, and not able to guarantee that all other processes were killed!
[/color]
This is a problem when I try to run code which uses a custom shared library based on NGSolve libraries but which is not designed for openmpi and doesn’t need the netgen gui.
Is there a way to build my custom library so the mpi dependencies are not included so it can still be used by code that is run directly from python? – or is it recommended to have two builds of NGSolve - one for parallel and one for serial?
Thanks!
Dow
