Hi, I’m trying a cmake configuration script like this on Ubuntu 20.04:
export BASEDIR=$HOME/ngsuite
rm -rf $BASEDIR/ngsolve-build
rm -rf $BASEDIR/ngsolve-install
mkdir $BASEDIR/ngsolve-build
mkdir $BASEDIR/ngsolve-install
cd $BASEDIR/ngsolve-build
cmake -DUSE_JPEG:BOOL=ON \
-DUSE_MKL:BOOL=ON \
-DMKL_ROOT:PATH=$HOME/intel/oneapi/mkl/2021.2.0 \
-DUSE_UMFPACK:BOOL=ON \
-DUSE_MPI:BOOL=ON \
-DUSE_MUMPS:BOOL=ON \
-DCMAKE_INSTALL_PREFIX:PATH=${BASEDIR}/ngsolve-install ${BASEDIR}/ngsolve-src
I really just wanted to try MUMPS as a sparse solver in a non-MPI context, but I don’t mind having a parallel build. I noticed that if the MUMPS flag is set without the MPI flag, CMake fails to configure
CMake Error at cmake/external_projects/mumps.cmake:9 (find_package):
By not providing “FindPARMETIS.cmake” in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by “PARMETIS”,
but CMake did not find one.
Could not find a package configuration file provided by “PARMETIS” with any
of the following names:
PARMETISConfig.cmake
parmetis-config.cmake
Add the installation prefix of “PARMETIS” to CMAKE_PREFIX_PATH or set
“PARMETIS_DIR” to a directory containing one of the above files. If
“PARMETIS” provides a separate development package or SDK, be sure it has
been installed.
cmake/SuperBuild.cmake:212 (include)
CMakeLists.txt:57 (include)
If I remove both MUMPS and MPI, the build always works, and the Pardiso inverse from MKL is available. I have a local Pardiso installed from Intel OneAPI
With the configuration at the top of this post (both MUMPS and MKL set), I don’t see any issues in the configuration step, Netgen and NGSolve build except for the final step when NGSolve gives a linker error about missing libblacs-related definitions.
[ 99%] Linking CXX executable ngs
/usr/bin/ld: …/linalg/libngla.so: undefined reference to blacs_gridinfo_' /usr/bin/ld: ../linalg/libngla.so: undefined reference to
pzpotrf_’
/usr/bin/ld: …/linalg/libngla.so: undefined reference to pdpotrf_' /usr/bin/ld: ../linalg/libngla.so: undefined reference to
pdgetrs_’
/usr/bin/ld: …/linalg/libngla.so: undefined reference to blacs_gridexit_' /usr/bin/ld: ../linalg/libngla.so: undefined reference to
numroc_’
/usr/bin/ld: …/linalg/libngla.so: undefined reference to pdgetrf_' /usr/bin/ld: ../linalg/libngla.so: undefined reference to
pzgetrs_’
/usr/bin/ld: …/linalg/libngla.so: undefined reference to blacs_gridinit_' /usr/bin/ld: ../linalg/libngla.so: undefined reference to
descinit_’
/usr/bin/ld: …/linalg/libngla.so: undefined reference to pzgetrf_' /usr/bin/ld: ../linalg/libngla.so: undefined reference to
pdpotrs_’
/usr/bin/ld: …/linalg/libngla.so: undefined reference to `pzpotrs_’
collect2: error: ld returned 1 exit status
I have openmpi3 installed through apt. I tried installing scalapack through apt also, but that didn’t seem to help with the linker issue. I see libmkl-blacs-openmpi packages available, but I haven’t tried them. I’m not sure if my installation of the Intel OneAPI might also include a blacs implementation.
If anyone has ideas on how to get past this linker error, that would be great. I’m attaching a file with the full build output.
Thanks!
Dow
Attachment: build-dump.txt
