petsc linking
hello, I would like to know if its possible to use PETSc solvers in NGsolve.
Regards
Tom
Hi Tom,
actually I was interested in this for some time now, your question pushed me to try it :wink:
It should be possible using the petsc4py interface. Note that I have no experience at all with petsc and the documentation of their Python interface is not existent… Maybe some things can be done more elegant :wink:
I’ve modified the poisson.py example to use a petsc solver, interfacing with numpy/scipy. Note that on our side no copies are made only type conversions - petsc may do copy / mpi communcations
First we set up the ngsolve problem:
import petsc4py
petsc4py.init()
import petsc4py.PETSc as psc
from scipy.sparse import csr_matrix
fes = H1(mesh, order=3)
f += SymbolicLFI(32 * (y*(1-y)+x*(1-x)) * v)
a += SymbolicBFI(grad(u)*grad(v))
a += SymbolicBFI(1e6* u*v, definedon=mesh.Boundaries("top|bottom|right|left"))
Then wrap our data with petsc classes and solve there (and draw the solution):
fpsc = psc.Vec()
fpsc.createWithArray(f.vec.FV().NumPy())
spy_csr = csr_matrix(a.mat.CSR(), shape=(a.mat.height, a.mat.width))
apsc = psc.Mat().createAIJ(size=spy_csr.shape)
apsc.setUp()
(Istart, Iend) = apsc.getOwnershipRange()
ai = spy_csr.indptr[Istart:Iend+1] - spy_csr.indptr[Istart]
aj = spy_csr.indices[spy_csr.indptr[Istart]:spy_csr.indptr[Iend]]
av = spy_csr.data[spy_csr.indptr[Istart]:spy_csr.indptr[Iend]]
apsc.setValuesCSR(ai,aj,av)
apsc.assemble()
ksp = psc.KSP()
ksp.create()
ksp.setOperators(apsc)
upsc = psc.Vec()
upsc.createWithArray(gfu.vec.FV().NumPy())
ksp.solve(fpsc,upsc)
Draw (gfu)
Since petsc writes the solution into our vector I assume at least for the vectors there are no copies involved.
I don’t know how to set dirichlet (non free dofs) for petsc so that it only solves on sub matrices, thats why I implemented the dirichlet boundaries with penalty terms.
Attachment: ngsolve_petsc.py
Thank you very much. I’m would like to try my problem in NGSolve as it supports p-refinement. I work on Maxwell’s equations and will get back to you after trying my problem using this script. Thanks again and merry x’mas !
regards
