Post-process the gfu, curl them
I want to post-process the gfu and curl them.
The type of A will be <class ‘ngsolve.fem.CoefficientFunction’> when after I do post-process.
Please tell me what to do. Thank you.
    solvers.CG(sol=gfu.vec, rhs=f.vec, mat=a.mat, pre=c.mat, printrates='\r', tol=1e-8, maxsteps=1000)
A = GridFunction(fes)
print(type(A))
A = 5*gfu
print(type(A))
B = curl(A)
<class ‘ngsolve.comp.GridFunction’>
AttributeError: ‘ngsolve.fem.CoefficientFunction’ object has no attribute ‘derivname’
First use curl and then scale it. Only the gridfunction itself can give the curl, if you scale it it is only a coefficientfunction and this doesn’t implement a curl.
Understood. Thank you for telling me :slight_smile:
Hello Christopher, I am totally new to NGSolve. I am looking for local element-wise matrix computation for HDG post-processing of the Poisson equation. Can you suggest how to do that, or do you have any examples?
