I would like to conver my gmsh mesh (.msh) to netgen format (.vol). The problem is when I load the .vol file on NGSOLVE (graphics interface) I only observe the meshing on the surface and not in the whole volume.
The code for transform the gmsh mesh is the following:
from netgen.meshing import *
# import the Gmsh 2.22 file to a Netgen mesh object
mesh = ReadGmsh("disk.msh")
mesh = Mesh(mesh)
mesh.ngmesh.Save("disk.vol")
The disk.msh is attached in zip format.
I have tried to put generate mesh (It is not the idea since I would like to be able to use the imported mesh from gmsh), but I obtain the following error:
SYSTEM ERROR: more elements on face
Thanks
Attachment: disk.zip
