Problem with input() and Netgen
Hi!
I would like to draw some functions in a for loop and visualize them using “input()” so I can check the result. The issue is that NGSolve crashes if I have an “input()” (even outside a loop as in the example below), giving me this error “Tcl_WaitForEvent: Notifier not initialized”.
Here is the small example I run:
mesh = Mesh (unit_square.GenerateMesh(maxh=1))
fes = H1(mesh, order = 1)
gfu.vec[:] = 0
input()
Thank you in advance!
Elena
hi,
what os do you use and how did you install? is it when you run with netgen or python?
what happens if you run with python -m netgen.gui script.py?
best Christopher
Hi Christopher,
I have a MacPro 2,3 GHz 8-Core Intel Core i9. The issue is when I run it with netgen but the command you suggested also gives the same error. I updated netgen to the latest version as well.
Thank you for the help!
Elena
Dear Christopher,
If I add “import netgen.gui” as library and run the code with “python script.py” now it works with the input() function.
Many thanks!
Elena
