Question regarding 1d HDG
Dear all,
usingmake_seg_mesh from ngsolve-src/py_tutorials/TensorProduct/make_seg_mesh.py, I tried the following example:
from make_seg_mesh import *
import matplotlib as mpl
ngsglobals.msg_level = 0
m2 = SegMesh(10,0,1,0)
m2.dim = 1
mesh = Mesh(m2)
Y = L2(mesh, order=1)  # space can be fixed for the whole routine
#Z = FacetFESpace(mesh, order=0,dirichlet = [1,2])
#X = FESpace([Y,Z])
u = GridFunction(Y)
print("Size of u.vec = " + str(u.vec.size)) # returns 20, each element has two degrees of freedom
u.Set(x)
print(u.vec) # Strange result
To my understanding, I am creating an L^2-Space of order one with 10 elements, so each element has two degrees of freedom (1d), one on the left, one on the right. Thus u.vec.size is 20.
However, I would expect that every second entry in this vector corresponds to the same (physical) vertex point and thus, calling u.Set(x), i would expect a result like, e.g.
0.05
0.15
0.15
however, instead I get
0.05
0.15
0.25
0.35
0.45
0.55
0.65
0.75
0.85
0.95
0.05
0.05
0.05
0.05
0.05
0.05
0.05
0.05
0.05
0.05
I this a misunderstanding or is there something wrong with .Set(x) in 1d?
thanks,
Jan
Attachment: DG_1d_test.py
hi jan,
it seems that you are just expecting a different basis (and numbering). The L2 space has an L2 orthogonal basis (not the hat function basis!). Moreover, lowest order dofs are numbered first (unless you use a flag not to do that). the lowest order dofs are the mean values, which fits your values. The second dof per element corresponds to the second legrende polynomial. This is the same coefficient for all elements if you set a linear function.
Btw.: you can also visualize the basis functions by setting a gridfunctions vector to the unit vector.
