RE: pip installer
Hi all,
I’ve able to use pip3 install ngsolve without problems to install the latest version of NG-Solve on an Unbuntu based linux system. But, if try to do the same on a different linux system we have in the department (looks to be an older Redhat system, where I don’t have su access) I get the errorpip3 install ngsolveERROR: Could not find a version that satisfies the requirement ngsolve (from versions: none)ERROR: No matching distribution found for ngsolve I can install other standard libraries eg numpy, scipy, matplotlib etc using pip3 without problems. The python version is 3.8.9. Is it perhaps because the pip installer is not available for this linux version?
Thanks for your help
Paul
