I am working on the stationary Stokes problem. My advisor told me that the stability of Taylor-hood elements for the Stokes problem when using triangular elements requires that each element only has maximum one side on the boundary. Hence, we thought to use a large mesh that satisfies this, and then refine it. However, the error of the solution diverges with more refinements. Any idea’s? The code is found below.
Alvar
basic xfem functionality
basic geometry features (for the background mesh)
import netgen.gui
from numpy import pi
import scipy
import scipy.sparse as sp
geo.AddRectangle( (0, 0), (1, 1), bcs = (“top”, “left”, “bottom”, “right”))
#uex = CoefficientFunction((2pisin(pix)**2cos(piy)sin(piy), -2pisin(pix)cos(pix)sin(piy)2))
#force = CoefficientFunction((12*pi3sin(pix)2sin(piy)cos(piy) - pisin(pix)cos(piy) - 4*pi3sin(piy)cos(pix)2cos(piy),-12*pi3sin(pix)sin(piy)2cos(pix) + 4*pi3sin(pix)cos(pix)cos(piy)**2 - pisin(piy)cos(pix)))
#pex = CoefficientFunction(cos(pi*x)cos(piy))
nu = 1
#uex = CoefficientFunction((sin(piy), -cos(pix)))
#force = CoefficientFunction((-pisin(pix)cos(piy) + nu * pi2sin(piy), -pisin(piy)cos(pix) - nu * pi2cos(pix)))
#uex = CoefficientFunction((sin(y) + cos(y), 0))
#force = CoefficientFunction((sin(y) + cos(y) + cos(x),0))
#pex = sin(x)
uex = CoefficientFunction((y*(1-y), 0))
force = CoefficientFunction((3,0))
pex = CoefficientFunction(x-1/2)
l22_list = []
l2p_list = []
def my_abs(mesh, v, h0):
a = 0
x = np.arange(0,1+h0, h0)
for i in range(len(x)):
for j in range(len(x)):
p1 = np.array([x[i]])
p2 = np.array([x[j]])
mip = mesh(p1, p2)
val = abs(v(mip))
a = max(a, val)
return a
def l2error(refinement = 0, structured = False, quad = False):
order = 2
alpha = 10
h0 = 0.3
if structured:
mesh = Mesh(geo.GenerateMesh(maxh = h0, quad_dominated = quad))
for i in range(refinement):
#Draw(mesh)
mesh = Mesh(geo.GenerateMesh(maxh = h0*2**(-refinement), quad_dominated = quad))
#Wh = HDiv(mesh, order = order+1, dgjumps = True, BDM = True) #Velocity space
Wh = VectorH1(mesh, order = order, dgjumps = True) #Velocity space
Qh = L2(mesh, order = order-1) #Pressure space
Nh = NumberSpace(mesh) #Lagrange multiplier
Vh = FESpace([Wh,Qh,Nh], dgjumps = True)
u,p,r = Vh.TrialFunction()
v,q,s = Vh.TestFunction()
tang = lambda v:v #If no tangential projections are wanted
#tang = lambda v: v-(v*n)*n #If tangential projections are wanted
jump_u = tang(u-u.Other())
jump_v = tang(v-v.Other())
flux_u = 0.5*(grad(u) + grad(u.Other()))*n
flux_v = 0.5*(grad(v) + grad(v.Other()))*n
a = BilinearForm(Vh)
#Volume integrals
a += SymbolicBFI(nu*InnerProduct(grad(u), grad(v)))
a += SymbolicBFI(-div(u)*q) #consistent symmetrizing term
a += SymbolicBFI(-div(v)*p)
a += SymbolicBFI(p*s)
a += SymbolicBFI(q*r)
#Interior facet integrals
a += SymbolicBFI(-nu*InnerProduct(flux_u,jump_v), VOL, skeleton = True)
a += SymbolicBFI(-nu*InnerProduct(flux_v,jump_u), VOL, skeleton = True) #consistent symmetrizing term
a += SymbolicBFI(h**(-1) * alpha * order**2 * InnerProduct(jump_u,jump_v), VOL, skeleton=True) #consistent stabilizing term
#Boundary facet integrals
a += SymbolicBFI(-nu*InnerProduct(Grad(u)*n,tang(v)), BND, skeleton = True)
a += SymbolicBFI(-nu*InnerProduct(Grad(v)*n,tang(u)), BND, skeleton = True) #symmetrizing term
a += SymbolicBFI(h**(-1) * alpha * order**2 * InnerProduct(tang(u),tang(v)), BND, skeleton=True) #stabilizing term
a += SymbolicBFI(v*n*p, BND, skeleton=True)
a += SymbolicBFI(u*n*q, BND, skeleton=True) #symmetrizing term
#Right-hand side
f = LinearForm(Vh)
f += SymbolicLFI(force*v)
f += SymbolicLFI(-nu*InnerProduct(Grad(v)*n,uex),BND, skeleton = True) #symmetrizing term
f += SymbolicLFI(h**(-1) * alpha * order**2 * InnerProduct(uex,v), BND, skeleton=True) #stabilizing term
f += SymbolicLFI(uex*n*q, BND, skeleton = True) #symmetrizing term
f += SymbolicLFI(pex*s)
gfu = GridFunction(Vh)
gfuex = GridFunction(Wh)
gfuex.Set(uex)
gfpex = GridFunction(Qh)
gfpex.Set(pex)
a_inv = a.mat.Inverse(freedofs = Vh.FreeDofs(), inverse="umfpack")
gfu.vec.data = a_inv*f.vec
vel = gfu.components[0]
pres = gfu.components[1]
#Draw(pres, mesh, "p")
#Draw(vel, mesh, "u")
#Draw(div(vel), mesh, "div(u)")
#Draw(Norm(vel), mesh, "|u|")
dv = grad(vel)
dg = grad(gfuex)
divu = div(vel)
#eu = sum((dv-dg)**2)
eu = (vel - gfuex)**2
ep = (pres - gfpex)**2
err = vel-gfuex
Draw(Norm(err), mesh, "|e|")
l22 = Integrate(eu, mesh)
l2p = Integrate(ep, mesh)
l22_list.append(l22)
l2p_list.append(l2p)
print("\nRefinement level ", refinement)
print("L2 error in velocity: ", sqrt(l22))
print("L2 error in pressure: ", sqrt(l2p))
print("div(u)-norm", Integrate(divu**2, mesh))
if len(l22_list)>1:
print("EOCu: ", (np.log(sqrt(l22_list[-2]))-(np.log(sqrt(l22_list[-1]))))/np.log(2))
print("EOCp: ", (np.log(sqrt(l2p_list[-2]))-(np.log(sqrt(l2p_list[-1]))))/np.log(2))
for i in range(3,4):
l2error(i, structured = True, quad = False)
