region Mask question
in Python, I can create and save a mesh with two regions like this:
geo = SplineGeometry() geo.AddRectangle((0,0), (2,2), bcs=["b","r","t","l"], leftdomain=1) geo.AddRectangle((1,0.9), (1.3,1.4), bcs=["b2","r2","t2","l2"], leftdomain=2, rightdomain=1) geo.SetMaterial (1, "outer") geo.SetMaterial (2, "inner") mesh = Mesh(geo.GenerateMesh(maxh=0.1)) mesh.ngmesh.Save("mesh2.vol")
Now I can load the mesh and get its materials and see that their masks are correct
[code]mesh = Mesh(“mesh2.vol”)
mesh.GetMaterials()
(‘outer’, ‘inner’)
print(mesh.Materials(“inner”).Mask())
0: 01 # Correct
print(mesh.Materials(“outer”).Mask())
0: 10 # Correct
[/code]The Pybind bindings in python_comp_mesh.cpp are like this:
[code] py::class_<MeshAccess, shared_ptr> mesh_access(m, “Mesh”,
.def(“GetMaterials”,
(const MeshAccess & ma)
return MakePyTuple(ma.GetMaterials(VOL));
“Return list of material names”)
.def("Materials",
     [](const shared_ptr<MeshAccess> & ma, string pattern)
        return Region (ma, VOL, pattern);
     py::arg("pattern"),
     docu_string("Return mesh-region matching the given regex pattern"))
py::class_ (m, “Region”, “a subset of volume or boundary elements”)
.def(“Mask”,(Region & reg)->BitArray { return reg.Mask(); }, “BitArray mask of the region”)
[/code]
Now if I try to do the same in C++ that I did in Python
// ngscxx -c mask_test.cpp ; ngsld mask_test.o -lngcomp -lngcore -lmesh #include <solve.hpp> using namespace ngsolve; int main(int argc, char** argv) { auto ma = make_shared<MeshAccess>("mesh2.vol"); cout << ma->GetMaterials(VOL) << endl; // correctly prints: 0:outer 1:inner int nreg = ma->GetNRegions(VOL); cout nreg << endl; // correctly prints: 2 auto inner = Region(ma, VOL, "inner"); auto outer = Region(ma, VOL, "outer"); cout << inner.Mask() << endl;
// 0: 11 // Wrong!!! cout << outer.Mask() << endl;
// 0: 11 // Wrong!!! return 0; }
Some of our C++ code similiar to this example worked until an NGSolve update about a week ago (or maybe a month ago).
Dow
Hi Dow,
there is now a new Region - constructor with the third argument a bool.
The char* is converted to the bool and not to the string.
it works if you write:
auto inner = Region(ma, VOL, string(“inner”));
That’s a dangerous pitfall, think we should get rid of the new ctor.
