Resonance with square scatterer
Edited: I am very new to NGSolve. I’m trying to verify some resonance values that I’ve solved for through collocation methods on the integral equation form for the 2D Helmholtz equation with constant value scatterer, the scatterer has value 3, so the equation looks like
[tex]\Delta u + 3 \lambda u =0[/tex]
with Sommerfeld radiation conditions.
I’m using the tutorial as well as things I’ve seen on other posts and have the following code:
[code]geo = SplineGeometry()
Points = [(0,0), (1,0), (1,1), (0,1)]
for pnt in Points:
geo.AddPoint(*pnt)
for pids in [[0,1],[1,2],[2,3], [3,0]]:
geo.Append([“line”]+pids,leftdomain=1,rightdomain=2,bc=“scat”)
geo.AddCircle( (0.5,0.5), 1.2, leftdomain=3, bc=“outerbdn”)
geo.AddCircle( (0.5,0.5), 1.0, leftdomain=2, rightdomain=3, bc=“innerbdn”)
geo.SetMaterial(1, “inner”)
geo.SetMaterial(2, “air”)
geo.SetMaterial(3, “pmlregion”)
mesh.Curve(3)
mesh.SetPML(pml.Radial(rad=1,alpha=1j,origin=(0.5,0.5)), “pmlregion”)
omega_0 = 1
omega_tilde = 3
domain_values = {‘inner’: omega_tilde,‘air’: omega_0, ‘pmlregion’: omega_0}
values_list = [domain_values[mat] for mat in mesh.GetMaterials()]
omega = CoefficientFunction(values_list)
Draw(omega, mesh, ‘piecewise’)
fes = H1(mesh, order=4, complex=True, dirichlet=“dir”)
u = fes.TrialFunction()
v = fes.TestFunction()
a = BilinearForm (fes, symmetric=True)
a += grad(u)*grad(v)*dx
m = BilinearForm (fes, symmetric=True)
m += uvdx
m.Assemble()
u = GridFunction(fes, multidim=50, name=‘resonances’)
lam = ArnoldiSolver(a.mat, m.mat, fes.FreeDofs(),
u.vecs, shift=0)
Draw(u)
print ("lam: ", lam)
[/code]
If someone can let me know if this is actually solving for the resonance values with a [0,1]x[0,1] square scatterer with value 3 I would be greatly appreciative.
