Safty check for matrix inversion
When umfpack direct solver fails to factorize the linear system (due to singularity), the code simply crashes.
Is there a safer way to proceed other than producing the following error message and exit the code?
netgen.libngpy._meshing.NgException: UmfpackInverse: Numeric factorization failed.
I noticed pardiso solver will still proceed with the factorization, but producing nan values.
Guosheng
Hi Guosheng,
you can use the try - except syntax of Python
try:
    a.mat.Inverse(fes.FreeDofs(), inverse="umfpack")
except:
   print("Singular matrix")
Then the code does not exit.
