Segmentation fault while calling ngsolve library
Hi:
I am using the following python script in which I call both netgen and ngsolve:
import the Gmsh file to a Netgen mesh object
mesh = ReadGmsh(“output”)
wrap it into an NGSolve mesh
mesh = Mesh(mesh)
mesh.ngmesh.Save(“netgen_cube.vol”)
print (“num vol elements:”, mesh.GetNE(VOL))
print (“num bnd elements:”, mesh.GetNE(BND))
I have build netgen on an linux machine with no gui availbale and there has no error while building it while following the build instruction. The error which I get when I is the following:
python3 testgmsh.py (testgmsh.py is the name of the file)
set global mesh
zsh: segmentation fault (core dumped) python3 testgmsh.py
This error arises when control reaches “from ngsolve import *” although I am able to call netgen and associated function
Would you try running it in the debugger to see where exactly the segfault happens?
Just run
gdb -ex run -ex bt --args python3 testgmsh.py
and append the complete console output.
hi Matthiash,
I have added the full output in text file (console_output.txt with this reply) from console after running the script in debugger. I also wanted to add that same segfault occurs when I call netgen only which is as follows:
togl-version : 2
no OpenGL
loading ngsolve library
zsh: segmentation fault (core dumped) netgen
Regards
Reegards
Ankit
Attachment: console_output_2018-02-16.txt
