Hello, everyone,
I am trying to construct a custom mesh in 2d on a circle shaped domain with special properties. I am nearly finished, but I noticed that I am not able to add different materials to my mesh and even though the visualization shows 2 different domains mesh.GetNDomains() results in 1. I have already tried to set all domain IDs correctly and also added FaceDescriptors for the boundaries so I don’t know where the problem could be. Here is a shortened version of my code that showcases my problem:
import netgen.meshing as ngm
###desired geometry
radius=0.9
center=(0,0)
geo = geom2d.SplineGeometry()
geo.AddCircle(c=center,r=1,leftdomain=3,bc='o')
geo.AddCircle(c=center, r=radius, leftdomain=4,rightdomain=3)
###geometry inner circle
geo_ref= geom2d.SplineGeometry()
geo_ref.AddCircle(c=center, r=radius)
mesh_ref=geo_ref.GenerateMesh(maxh=0.1)
###Generate custom mesh
mesh=ngm.Mesh()
mesh.SetGeometry(geo)
pmap = { }
pmap1= { }
fd_inter = mesh.Add(ngm.FaceDescriptor(bc=2))
fd_insideb = mesh.Add(ngm.FaceDescriptor(bc=1))
f_in=1
f_out=2
#Build custom mesh
points=mesh_ref.Points()
for e in mesh_ref.Elements1D():
for v in e.vertices:
if (v not in pmap):
pmap[v] = mesh.Add(mesh_ref[v])
point=points[v]
alpha=1+0.1/radius
new_point=(alpha*point[0]+(1-alpha)*center[0],alpha*point[1]+(1-alpha)*center[1])
pmap1[v]=mesh.Add(ngm.MeshPoint(ngm.Pnt(new_point[0], new_point[1],0)))
nr=e.edgenr
verts=[pmap[v] for v in e.vertices]
mesh.Add(ngm.Element1D(verts,index=fd_insideb,edgenr=nr+4))
verts1=[pmap1[v] for v in e.vertices]
mesh.Add(ngm.Element1D(verts1,index=fd_inter,edgenr=nr))
verts.reverse()
mesh.Add(ngm.Element2D(f_out, verts+verts1))
for f in mesh_ref.Elements2D():
for v in f.vertices:
if (v not in pmap):
mesh.Add(ngm.Element2D(f_in,[pmap[v] for v in f.vertices]))
#set materials (seems to be doing nothing)
mesh.SetMaterial(1,"Mat1")
mesh.SetMaterial(2,"Mat2")
ngmesh=Mesh(mesh)
print(ngmesh.GetMaterials())
print(mesh.GetNDomains())
I appreciate your help.
Sincerely,
Florian
