Singly diagonally implicit Runge-Kutta methods for time stepping
I am a bit confused about the implementation of SDIRK method in ngsolve when i studied the SDIRK method in i-tutorial unit 3.1
introduction of SDIRK method
Let us consider more sophisticated time integration methods, SDIRK methods. To simplify presentation we set f=0.
SDIRK methods for the semi-discrete problem
\frac{d}{dt} u = M^{-1} F(u) = -M^{-1} \cdot A u
are of the form:
u^{n+1} = u^n + \Delta t M^{-1} \sum_{i=0}^{s-1} b_i k_i
with k_i = - A u_i , where u_i is the solution to
(M + a_{ii} \Delta t A) u_i = M u^n - \Delta t \sum_{i=0}^{i-1} a_{ij} k_j, \quad i=0,..,s-1.
The coefficients a,b and c are stored in the butcher tableau:
\begin{array}{c|cccc} c_0 & a_{00} & 0 & \ddots& \\ c_1 & a_{10} & a_{11} & 0 & \ddots \\ \vdots & \vdots & \vdots & \ddots & 0\\ c_{s-1} & a_{s-1,0} & a_{s-1,1} & \dots& a_{s-1,s-1} \\ \hline & b_{0} & b_1 & \dots& b_{s-1} \\ \end{array}
For an SDIRK method we have a^\ast = a_{ii},~i=0,..,s-1.
implementation
  • butcher tableau
class sdirk5: #order 4
    stages = 5
    a = [[1/4, 0, 0, 0, 0],
         [1/2, 1/4, 0, 0, 0],
         [17/50,-1/25, 1/4, 0, 0],
         [371/1360, -137/2720, 15/544, 1/4,0],
         [25/24, -49/48, 125/16, -85/12, 1/4]]
    b = [25/24, -49/48, 125/16, -85/12, 1/4]
    c = [1/4, 3/4, 11/20, 1/2, 1]
    astar = 1/4
  • time stepping function
def TimeStepping_app4(m, a, butchertab, dt,
                      initial_cond = None, t0 = 0, tend = 2,
                      nsamples = 10):
    mstar.AsVector().data = m.mat.AsVector() + butchertab.astar * dt * a.mat.AsVector()
    invmstar = mstar.Inverse(freedofs=fes.FreeDofs())
    invmass = m.mat.Inverse(freedofs=fes.FreeDofs())
    rhsi, Mu0, ui = gfu.vec.CreateVector(),gfu.vec.CreateVector(),gfu.vec.CreateVector()
    k = [gfu.vec.CreateVector() for i in range(butchertab.stages)]
    if initial_cond:
        gfu.Set(initial_cond)
    cnt = 0; time = t0
    sample_int = int(floor(tend / dt / nsamples)+1)
    gfuD = GridFunction(gfu.space)
    gfut = GridFunction(gfu.space,multidim=0)
    gfut.AddMultiDimComponent(gfu.vec)
    while time < tend - 0.5 * dt:
        Mu0.data = m.mat * gfu.vec
        for i in range(butchertab.stages):
            rhsi.data = Mu0
            for j in range(0,i):
                rhsi.data += dt * butchertab.a[i][j] * k[j]
            t.Set(time+butchertab.c[i]*dt)
            gfu.Set(uD,BND)
            ui.data = gfu.vec; rhsi.data -= mstar * ui
            ui.data += invmstar * rhsi
            k[i].data = - a.mat * ui
        t.Set(time+dt)
        gfu.Set(uD,BND)
        Mu0.data -= m.mat * gfu.vec
        for i in range(0,butchertab.stages):
            Mu0.data += dt * butchertab.b[i] * k[i]
        gfu.vec.data += invmass * Mu0
        print("\r",time,end="")
        if cnt % sample_int == 0:
        cnt +=
questions
  • inconsistency between formulas and codes
    when we use the results of previous sub-steps u_{j} to compute u_{i}, i think the formula should be of the following form (formula in the tutotial made a small mistake in \Sigma)
(M + a_{ii} \Delta t A) u_i = M u^n - \Delta t \sum_{j=0}^{i-1} a_{ij} k_j, \quad i=0,..,s-1.
The implementation of the formula is as follows (i add some comments with #====)
     #====now we have rhs = Mu^{n}====
     rhsi.data = Mu0
          #====why not rhsi.data -= dt * butchertab.a[i][j] * k[j]====
     #====time-dependent boundary conditions====
     gfu.Set(uD,BND)
     ui.data = gfu.vec
     #====homogeneous + BC====
t.Set(time+dt)
Is there a sign problem? (rhsi.data += dt * butchertab.a[i][j] * k[j] for M u^n - \Delta t \sum_\limits{j=0}^{i-1} a_{ij} k_j, \quad i=0,..,s-1.)
indeed the sign in the writen formula is wrong. The code should however be ok.
Thanks for the careful check an report!
Thanks for your quick reply. In this tutorial, i think there is indeed only one small error with the subscript of sum in the formula((M + a_{ii} \Delta t A) u_i = M u^n - \Delta t \sum\limits_{i=0}^{i-1} a_{ij} k_j, \quad i=0,..,s-1. should be (M + a_{ii} \Delta t A) u_i = M u^n - \Delta t \sum\limits_{j=0}^{i-1} a_{ij} k_j, \quad i=0,..,s-1.) and a sign error in the corresponding code.
