Hi all ![]()
i like to do the surface pde example but with a geometry that comes from some stl file.
is this possible ?
i would be happy if some one could tell me ![]()
Hi all ![]()
is this possible ?
I have now combined the surface pde example with the, manual mesh generation example, i think thats a good startingpoint but i do not know how to set dirichlet bnd conditions, would be great if some one can help me :).
I get in the console “used dof inconsistency” … if i run the following code …
from netgen.csg import *
from ngsolve import Draw
ngmesh = netgen.meshing.Mesh(dim=2)
N=5
pnums = []
for i in range(N + 1):
for j in range(N + 1):
pnums.append(ngmesh.Add(netgen.meshing.MeshPoint(Pnt(i / N, j / N, 0))))
idx_dom = ngmesh.AddRegion("mat", dim=2)
for j in range(N):
for i in range(N):
ngmesh.Add(netgen.meshing.Element2D(idx_dom, [pnums[i + j * (N + 1)],
pnums[i + (j + 1) * (N + 1)],
pnums[i + 1 + (j + 1) * (N + 1)],
pnums[i + 1 + j * (N + 1)]]))
# horizontal boundaries
for i in range(N):
ngmesh.Add(netgen.meshing.Element1D([pnums[N + i * (N + 1)],
pnums[N + (i + 1) * (N + 1)]], index=1))
ngmesh.Add(netgen.meshing.Element1D([pnums[0 + i * (N + 1)], pnums[0 + (i + 1) * (N + 1)]], index=1))
# vertical boundaries
for i in range(N):
ngmesh.Add(netgen.meshing.Element1D([pnums[i], pnums[i + 1]], index=2))
ngmesh.Add(netgen.meshing.Element1D([pnums[i + N * (N + 1)], pnums[i + 1 + N * (N + 1)]], index=2))
# geo = CSGeometry()
# sphere = Sphere(Pnt(0,0,0), 1)
# bot = Plane(Pnt(0,0,0), Vec(0,0,-1))
# finitesphere = sphere * bot
# geo.AddSurface(sphere, finitesphere.bc("surface"))
# geo.NameEdge(sphere,bot, "bottom")
# mesh = Mesh(geo.GenerateMesh(maxh=0.3))
# mesh.Curve(2)
# Draw(mesh)
fes = H1(mesh, order=2, dirichlet=[1, 2])
u, v = fes.TnT()
print(fes.FreeDofs())
a += grad(u).Trace()*grad(v).Trace()*ds
force = 1.0
f += force*v*ds
gfu.vec.data = a.mat.Inverse(fes.FreeDofs())*f.vec
Draw(gfu, mesh, "u")
Hi Kai,
with ngmesh = netgen.meshing.Mesh(dim=2) you are creating a 2D mesh, not a surface mesh in 3D.
Thus, with a += grad(u).Trace()*grad(v).Trace()*ds you are integrating only over the four edges. This gives the used_dof_inconsistence warning.
I changed/added the following lines, compare attached file, to get the desired result. As stated in the surface pde tutorial you need the keyword dirichlet_bbnd instead of dirichlet to set Dirichlet boundary conditions for surface PDEs.
[code]ngmesh = netgen.meshing.Mesh(dim=3)
ngmesh.SetCD2Name(1, “top_bot”)
ngmesh.SetCD2Name(2, “left_right”)
fes = H1(mesh, order=2, dirichlet_bbnd=“top_bot|left_right”)[/code]
https://ngsolve.org/media/kunena/attachments/889/surface_pde.py
Attachment: 70741d8fdcc071269c78e9fa9db83d65
