I’m trying to solve a problem with a third-order tensor.
For the MRE, assume it’s just 9 times the Poisson equation.
MRE:
from ngsolve.meshes import MakeStructured3DMesh
res = 3
mesh = MakeStructured3DMesh(False, nx=res,ny=res,nz=res, mapping=lambda x,y,z : (-1+2*x,-1+2*y,-1+2*z))
fes = MatrixValued(H1(mesh, order=order, dirichlet="left|right"), symmetric = False)
(S), (T) = fes.TnT()
GradS = CF( (
S[0,0].Diff(x), S[0,0].Diff(y), S[0,0].Diff(z),
S[0,1].Diff(x), S[0,1].Diff(y), S[0,1].Diff(z),
S[0,2].Diff(x), S[0,2].Diff(y), S[0,2].Diff(z),
S[1,0].Diff(x), S[1,0].Diff(y), S[1,0].Diff(z),
S[1,1].Diff(x), S[1,1].Diff(y), S[1,1].Diff(z),
S[1,2].Diff(x), S[1,2].Diff(y), S[1,2].Diff(z),
S[2,0].Diff(x), S[2,0].Diff(y), S[2,0].Diff(z),
S[2,1].Diff(x), S[2,1].Diff(y), S[2,1].Diff(z),
S[2,2].Diff(x), S[2,2].Diff(y), S[2,2].Diff(z),
), dims=(3,3,3) )
GradT = CF( (
T[0,0].Diff(x), T[0,0].Diff(y), T[0,0].Diff(z),
T[0,1].Diff(x), T[0,1].Diff(y), T[0,1].Diff(z),
T[0,2].Diff(x), T[0,2].Diff(y), T[0,2].Diff(z),
T[1,0].Diff(x), T[1,0].Diff(y), T[1,0].Diff(z),
T[1,1].Diff(x), T[1,1].Diff(y), T[1,1].Diff(z),
T[1,2].Diff(x), T[1,2].Diff(y), T[1,2].Diff(z),
T[2,0].Diff(x), T[2,0].Diff(y), T[2,0].Diff(z),
T[2,1].Diff(x), T[2,1].Diff(y), T[2,1].Diff(z),
T[2,2].Diff(x), T[2,2].Diff(y), T[2,2].Diff(z),
), dims=(3,3,3) )
F = CF( (1,1,1,
1,1,1,
1,1,1), dims=(3,3) )
a = BilinearForm(fes, symmetric=True, symmetric_storage=True, condense=False)
a += ( InnerProduct(GradT, GradS) )*dx
f += (InnerProduct(T, F))*dx
sol = GridFunction(fes)
sol.vec[:] = 0
r = sol.vec.CreateVector()
w = sol.vec.CreateVector()
inv = a.mat.Inverse(fes.FreeDofs(a.condense), inverse="umfpack")
a.Apply(sol.vec, r)
r.data -= f.vec
if a.condense:
r.data += a.harmonic_extension_trans * r
w.data = inv * r
if a.condense:
w.data += a.harmonic_extension * w
w.data += a.inner_solve * r
sol.vec.data -= w
For some reason this gives the error:
<ipython-input-171-2a6ac94913c7> in <module>
2 f.Assemble()
3 a.Assemble()
----> 4 inv = a.mat.Inverse(fes.FreeDofs(a.condense), inverse="umfpack") #umfpack,sparsecholesky
5
6 a.Apply(sol.vec, r)
NgException: UmfpackInverse: Numeric factorization failed.
Clearly, the Poisson problem is well-posed such that I don’t understand why umfpack fails.
I would be grateful for any insight!
